Question about Goodman CLQ36AR49 Air Conditioner
I need to know what wiring diagram to use for SSZ140421 Cond with AEPF426016 handler with HKR15C strips.
  • Goodman Master
  • 1,150 Answers
The AEPF number is for an Amana air handler. I have a manual for this number. Send me an email address and I can forward it to you. Manual has diagram.
Posted on Oct 07, 2010
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
Jun 17, 2017 | Intertherm Heating & Cooling
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
How to change a evep coil from a up flowunit to a down flow
What I have seen in the past and I have a few pictures, is you literally turn the entire Air handler upside down and insert the evaporator coil in so it would then be considered downflow, most ac companies have addition info in case you need any additional breacket etc.
Hope this helps.
Jun 02, 2013 | Goodman Manufacturing...
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
T stat wiring in air handler
Hi, normally they don' t have 2-toned striped wires in a thermostat cable. They must have used some other 18 gauge wire. If this is a gas fired indoor unit, the wires are Red to R, Yellow to Y, G to to green, and white to W. If its a heat-pump, no gas, you will have Red to R, W to W-1 if you have heat strips for second stage heat, G to fan, green, B is blue for the reversing valve, 0 will not be used on a Ruud. You may need to go to the control panel on the outdoor unit to see how they have wired the condenser, as you never no what colors they have picked to use, what ever suits them. You may have a black or brown for common if used, or for emergency heat. Gas air handlers are much easier to wire at the stat then a heat pump, so you will need to check what they used at the outdoor unit. They didn't use regular stat wire as it does not have stripes on it.Please do this and draw your self a diagram so you will know. Most all heat-pumps wire differently, at the stat depending on the kind, and at the condenser. I hope I have been of help to you on this as it is important to get it right, and it sound as tough you are familar with wiring. Please rate me on this and be kind as I know you will. Please keep me posted on the outcome or if you need more help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS You may not need any of the striped wires as all wires are not used. You will need to look at the outdoor and indoor control board.
Jul 17, 2010 | Ruud UBHC Air Conditioner
Air handler
This should be doable: First get pen and paper-start at the furnace, theres a group of 5-8 wires leaving the furnace anfd going to the thermostat and a group of 2-3 going to the condenser outside that all need to be identified and the location in the furnace recorded if your furnace has a control board simply right the letter and the corresponding wire color:and whether it belongs to the condenser grp or the T-stat grp.
Furnace
R-red-to t-stat
C-yellow to cond
Y-red to cond and yellow to t-stat
G- green-to t-stat
W- white- to t-stat
If you dont have a circuit board youll be doing the same thing but using the components rather than letters;
Transformer 24v- red to t-stat
transformer 24v com -yellow to cond
Red from cond connected to yellow from t-stat
fan relay - green to t-stat
gas valve - white to t-stat
K then go to you t-stat and simply connect the corasponding component or leter to the thermostat gterminal
Cond Furnace Thermostat
yellow com- blue -C or B
gas valve or w-white -W
fan relay or g -green -G
trans 24v or R -red - R
red connection to cond or Y on board -Y
Hope this helps.
Jun 12, 2008 | Quasar HQ2052UH Air Conditioner
RUUD HVAC UNIT - HEAT STRIPS COME ON WITH THE A/C
What you are talking about I think are the strip heaters in the Air Handler this must be a Heat Pump system right??? If so please check your thermostat and make sure it is not in EMRGY HEAT mode.. One other note there is a 2 stage bulb system inside the stat if it is too cold outside and the heatpump on its own cant keep up with the call for heat the 2nd bulb closes and turns on the heater as a supplumnetal heat also these will come on or should come on when the unit goes into defrost.. plz let me know what it is you are trying to test and i can walk you thru it.. Also need a model # off the A/H to get a Wiring diagram
Feb 03, 2008 | Ruud Handler Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
296 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
