Question about Canon PIXMA® mini260 InkJet Photo Printer
I am printing photos from Picasa 3.6 onto my Canon Pixma Mini 260. Photos come out green/yellow. I replaced the ink cartridge - same thing. I printed from the memory card - same thing. Any ideas?
  • cjohargreave Oct 07, 2010
    I followed your instructions to clean the print head and nozzles. I reassembled the printer and tried to print. Although the cartridge is brand new, the red light on the cartridge is steadily on, and ink is moving from the cartridge to the nozzles, no ink is transferring to the photo paper (in other words, the paper comes out blank). I tried the nozzle cleaning and other maintenance steps. I tried the auto head align with two sheets of paper and it failed repeatedly. The nozzle check pattern results in blank paper. I removed and reinstalled the print head but that didn't work either. What do you advise?
  • 857 Answers
Clean the print head and nozzles on the cartridge :
Follow these steps to clean the print head :-
Lift the printer cover to move the print carriage to the center position.
Press the tab on each cartridge and then lift to remove the cartridge.
Lift the lock to release the printhead, then lift the printhead out of the cradle.
Rinse the printhead with hot water. Gently remove any buildup of ink and paper residue that is stuck to the bottom of the head and clogging the holes and slits. Rinse until the water runs clean.
Remove the two screws from the ceramic plate on the bottom of the printhead.
Ease the ceramic plate away from the body of the printhead with gentle pressure. Run hot water behind the plate. Gently remove any buildup behind the plate. Rinse until the water runs clean.
Reassemble the printhead and then reinsert it into its cradle.
Lower the locking lever until it snaps into place, then reinstall the ink cartridges.
Close the printer cover, then perform any alignment adjustments recommended in the printer's operator manual.
STEPS TO CLEAN NOZZLES :
•1
Disconnect the printer from its power supply and remove the printing cartridges from the device. Most printers contain at least two cartridges, one for black and one for color.
•2
Locate the small holes in the printer where the toner cartridges were installed. Place 10 drops of isopropyl alcohol into each nozzle using an eyedropper.
•3
Use a Q-Tip moistened with alcohol to swab around the nozzles to loosen and remove any dried ink that has accumulated on top. Allow the alcohol to evaporate.
•4
Run the printer's cleaning and diagnostics test. Repeat steps 2 through 4 as needed until the printer produces clean copy.
Posted on Oct 07, 2010
  • Jayant Jha Oct 07, 2010
    I think the best will be is to get it serviced.
I have a canon pixma mini 260 i replaced the ink cartridge this morning and its allowing me to pick my photos and its printing but the photos are coming out blank?
its a common problem after getting refilled cartridge....
please insert a new catridge and try again.........
sure u can solve this problem.......
thank u .........
Jul 22, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced Yellow cartridge. Photos came out
Clean all cartridges to make sure ink is flowing. To do this put windoww cleaner ino a container about ten mm deep. Put the cartridges with the end where the ink comes out facing down into the container and soak for about ten minutes. After this dry off for with a paper towell and make sur each cartridge leaks color into the towell. may take a little shaking.
Sep 03, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Colour photo printing has a green tinge
This could be one of many things.
Monitor Calibration to Printer.
Camera green Bias
And good many more
The thing is not to print direct from camera , but to use an image editor to colour correct.
A free simple one is Googles free Picasa.
Otherwise there are many more some free a lot to be paid for.
As always there is a learning curve.
Sep 09, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA® mini260 InkJet Photo Printer Logo
83 people viewed this question
old marine
old marine
