Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 12 hp motor on my mower. At first it would only run at full choke. New it is not running at all and the compression is blowing out the carb and not sucking in. I changed the head gasket but it did not fix it. Getting about 60 PSI Compression.
Check your exhaust port. Something tells me the exhaust is clogged. Take off the muffler and see if problem continues.
Posted on Oct 07, 2010
04 330 magnum will not stay running without choke pulled out halfway to full choke from brand new in 2004
First make sure the carb.mounting flange is tight. being loose or cracked will allow air in leaning out the air fuel mixture. Next remove the low jet in the carb. its most likely plugged. try carb cleaner and blow it out with compressed air. Last resort,take the paper off of a twist tie and run it through the jet. If all else fails,buy a new one.thier only around 4 dollars.
Dec 14, 2014 | Polaris 2004 Magnum 330 4X4
Why wont briggs and stratton 12.5 h run without choke?
Carb is dirty and before you tear it really apart take the fuel bowl off if it has one and clean it real good and blow the dirt out of the fuel jet which is the bolt that holds the bowl on .That may be most of your problem. Drain the old gas and replace with fresh as well. Won't hurt to run some cleaner through as well.
Jun 22, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Craftsman 18.5 42"
Hi, does it have a fuel shutoff solenoid in the bottom of the carby? if so has it got a rubber tip on it? if so remove the rubber tip and try it as the rubber swells and restricts fuel flow. Also remove all carby jets again and clean down through them using some twisted multi strand wire and carb cleaner and air. Just blowing air through wont remove varnish deposits etc from the walls of the jets. Let me know how you go, regards Phil.
Aug 20, 2012 | Craftsman Garden
I have a John deere 316 with a onan and it will not run unless the choke is almost closed, I have checked the fuel flow and the compression and all seems good. What do you think is wrong?
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 22, 2012 | John Deere 420,1020,2010,2020,2510,2520...
My 13.5 ho b&s surges heavily but smoothed out when blade/ deck is engaged or when I apply choke. I've twice cleaned carbs and still now working. I ran in garage with no air filter to elimina
Feb 19, 2012 | Mtd Garden
Small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Sep 25, 2009 | Garden
Have to run tractor on full choke
Sir if you are running it on full choke then there is a blockage in the high speed jet inside the carb. Best solution would be a carb cleaning Hope this helps good luck!
Aug 10, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
253 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
