Question about Whirlpool RBS275PD Electric Single Oven
Where is the thermal fuse located on my whirlpool elecric oven model #RBS275PDQ Oven won't heat up after using self cleaning mode
  • 87 Answers
SOURCE: oven
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Posted on Jun 08, 2007
SOURCE: Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Posted on Aug 25, 2007
SOURCE: oven won't heat
I have EXACTLY the same problem, occured today 9/25/07. Model RBS305PDQ16. At least I know I am not crazy... You know when Ronald Regan was President the CIA analysts assured him that the Soviet Bloc was ready to crumble because the people were constatly complaining that "nothing seened to work anymore." ...must have included ovens...
Posted on Sep 26, 2007
SOURCE: WHIRLPOOL OVEN
nice, it'd help me a lot thank you
Posted on Jan 19, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
Self cleaned oven and now it will not heat up
Is this a Whirlpool or maybe a Kenmore. If so there is a thermal fuse that trips when self cleaned. It is located on the back of the oven you will have to pull the oven out and remove the back panel to find it.
Aug 28, 2014 | Ovens
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
My oven stopped heating after using self clean.
all whirlpool ovens have a thermal fuse on the back that will break when the oven gets to hot replace it and you will be working again
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
Oct 14, 2009 | Ovens
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBS275PD Electric Single Oven Logo
52 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
