Question about HP PSC 750 All-In-One InkJet Printer
Scanner tries to scan but light does not come on and copy is black
  • HP Master
  • 7,733 Answers
Try HP Support at http://welcome.hp.com/country/us/en/support_task.html
Posted on Oct 07, 2010
When i try to make a copy it comes out all black and when I try to scan something it is all black
Check the scanner bulb - it's suppose to light up when you copy or scan. Look inside the scan bed and as you copy or scan, it should light and move across the bed.
Feb 01, 2011 | HP PSC 1610 All-In-One InkJet Printer
My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Jul 17, 2010 | Visioneer RoadWarrior Patriot Handheld...
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
How do i use my scanner?
If you want Photocopy by using scanner just put your original document on scanner and press copy option.
here is two copy black and color for black copy and color copy
If you want to scan from printer to PC. Install scanner software from your driver CD and use scan sofware.
Remember that you can use only page for scan. can not use book. because this is not flatbed scanner.
Thanks
Sk. Abdus Sabur
Nov 29, 2009 | HP Officejet 4315v All-In-One InkJet...
Hi. I have a dell all-in-one printer. when i try
If you get black pages output from copies there is either light getting to the scanner (from an outside source) or the scanner itself is damaged. Most likely the latter issue. You can try puttnig a couple of extra pieces of paper on top of your scanned document before scanning (place the image directly on the glass, throw a few pieces of paper on top, and then close the cover. If the issues are still present there is a hardware failure with the scanner device itself.
Sep 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
Why do my copies come out so light?
I found that I had to adjust the settings or my copies were almost illegible. Instead of copying at greyscale or black & white, try setting for color copies (even if using a black & white laser printer) and 600 dpi. It takes a few seconds longer to scan, but you get very clear copies that way.
May 01, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
HP PSC 750 All-In-One InkJet Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
