Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60pp9202 will not power on
Started all of the sudden. Hit power button and nothing. Tried different outlet, etc. Where should I start? Could it be a fuse inside?
You should check the high voltage regulator inside the TV. Very common problem for this series. Be careful when removing them, it contains high voltage static charge in those capacitors.
Posted on Jun 11, 2008
Lenovo tower will not power up. Everything else on same power strip is working. Monitor, copier etc. I tried unplugging it and using a different outlet but still nothing. It was working fine yesterday...
If you tried a differwnt outlet in the strip I would take the tower or power supply out and have it tested at a repair shop. I am leaning towards a power supply fault, but I
have also seen where one of yhe outlets in a strip burns out. Sometimes the power supply has a green light near the power cord. If this is out then it will need replacing.
Dec 05, 2017 | Lenovo Computers & Internet
Pro Form 590s
I think you have the wrong category.
May 10, 2013 | Computers & Internet
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
Projector will not turn on. No lights no nothing
I opened mine up and in th front was a red reset button now I'm good!
May 22, 2009 | Sharp XR-11XC Multimedia Projector
No Power
Check the fuse on the small board on the far right inside the TV.
Oct 25, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Apr 07, 2008 | Philips 60PP9202 60" Rear Projection...
Does not get power from any wall outlet
First thing you may want to do is pull the back cover and see if the fust is blown next to the power cord. Make SURE the power cord is pulled before you try this. You could have had a power surge that caused it to go out, but usually this points to a larger problem. It's a good first pass thick to check though.
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
