Question about RMR-DLS315 Radar Detector
Ineed how operate X.K/KA.S1.S2.S3.C.L AND LASER SCRAMBLER INDICADOR
How can i test marine gyrocompass out put synchro and stepper
SYNCHRO MOTOR HAS THREE WINDINGS LIKE A STAR SOMETHING LIKE A THREE PHASE SAY S1,S2,S3 AND ANOTHER TWO WINDINGS CALLED R1ANDR2 , WHEN YOU SUPPLY EG 110VAC ACROSS R1 AND R2 IT GIVES A SECONDARY VOLTAGE ON THE S1,S2,S3 , SO YOU CAN CHECK IN THE MULTIMETER AC RANGE ACROSS S1-S2,S2-S3 AND S3-S1 , YOU SHOULD GET SAME VOLTAGE ACROSS ALL THESE POINTS .....hope that clears the question
Nov 22, 2014 | Boating
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
How to set time
First lets get the buttons identified. Electronic 4 button watches are probably controlled by the same chip. Top left is the light button. Going clock wise S2 (Stop/Start), S1 (Reset), and S3 (Mode). Press S3 button (lower left) 3 times.- Tuesday flag and seconds should flash. Press S2 and Seconds will set to 00. Press S1 one time, Minutes flash and advance by pushing S2. Press S1 again and Hour digits Flash and S2 makes them advance. Continue through Date, Month, Day. When finished press S3
Nov 13, 2014 | Adidas Mens Furano Adp6036 Black...
How do I change the time on my watch it's an adidas ADH6057?
Oct 01, 2014 | Adidas Watch ADH6057
HOW TO SET TIME FOR ADIDAS DIGITAL WATCH
Sep 10, 2014 | Adidas Mens Uraha ADP6013 Black Resin...
I have a ADP6013 digital watch. how do you set the time ?
Aug 23, 2014 | Adidas Watches
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
RMR-DLS315 Radar Detector Logo
57 people viewed this question
Top Rocky Mountain Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Rocky Mountain Vehicle Part and Accessory Expert? Answer questions, earn points and help others
