Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
The chain cover will not go back on because the break is engaged and I would like to know how to disengage the break band.
    Scholar:
  • 144 Answers
If the blade brake is engaged, it can be extremely hard to disengage when not mounted on the saw, as I'm sure you already know. One thing you can try is loosely mounting the cover on the bar studs with no sprocket installed so that you will have the leverage you need to disengage the brake band. Good luck.
Posted on Dec 14, 2010
Mulcher repair
follow this steps and fix it. God bless you
Clutch
If the chainsaw chain does not engage the clutch assembly might be worn out. The clutch is similar to an automotive clutch. The chain sprocket is attached to the clutch drum and there are clutch pads underneath. As the pads wear out the clutch assembly no longer engages with the motor and the chain does not engage either.
Clutch Band kit
Chainsaws are equipped with a clutch band, a steel band that wraps around the clutch drum and is activated by the emergency stop lever. If the lever does not disengage the chain does not engage. Check to be sure the stop lever is disengaged. Adjust the clutch band if necessary.
Enter your model number to see parts for your chainsaw.
Drum Brake
Chainsaws are equipped with a clutch band drum brake, a steel band that wraps around the clutch drum and is activated by the emergency stop lever. If the lever does not disengage the chain does not engage. Check to be sure the stop lever is disengaged. If necessary, adjust the clutch band drum brake.5bf7a198-4466-44ee-8866-ccfc5b95f0ac.jpg
Nov 24, 2013 | Garden
Husquvarna brake band adjustment
If you pulled the brake toward you to engage it, simply push it back out to disengage it. (might take more pressure to release it than to engage it)
Nov 19, 2013 | Husqvarna Model 460 Rancher Chainsaw 60cc...
Have tried everything but cover will not go back on the husqvarna 445. there is just not enough clearance for the band to go back onto the drum. have tried even adjusting the band tension but that...
The problem you are experiencing is very common. Many people remove the side cover with the chain brake applied or either the brake becomes engaged after the cover has been removed. You will need to reset the brake before you can install it. This is a little tricky but can be accomplished. I find that it is done fairly easy by carefully clamping the side cover in a vise, and using a good strong pair of needle nose, span the "rotator" (star shaped wheel) on the brake and with another pair of pliers, grab the needle nose pliers and "twist" the brake into the disengaged position. Hope this is explained well enough to get the job done.
Mar 04, 2011 | Husqvarna Chainsaw Piston Kit for 61...
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
I did not disengage the chain brake before removing the cover. Now after replacing the chain I can't get the cover back on.
I was just fighting this on husqvarna. I re-set the brake by fitting the cover tilted to the front, jiggling the chain brake handle to engage it with the brake sprocket. Once engaged, push handle back to unbraked position while bearing down on the cover. You'll feel the click as it locks back to unbraked position.
Nov 27, 2009 | 2008 Husqvarna TE 450
I have a Husqvarna 345e chainsaw. Can't get the cover back on.
That metal band you see which is preventing you from putting on the cover is part of the chain break mechanism. You were suppose to disengage the break before taking off the cover (I did the same thing). To get it back together you need to disengage the break by a tricky procedure and that will make the band diameter larger so it fits over the clutch. To force the band open, you need to first place the cover over the two bolts that hold the bar. As you already know, the back of the cover will not be able to fit over the clutch. Now in this angled position, bend (force) the break lever down (gray thing on top) until you can force together the sproket in the cover onto the mating pastic fitting built into the break lever. Now you can use the break lever to force down the internal spring and open the metal band. That will expand the stainless steel band and it will fit around the clutch. If you now push down on the back of the cover it will snap in over the clutch. Once you see how it is done, it is not so hard, but it is tricky because you are forcing some of the parts slightly out of position to get it back together. .
May 18, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Clutch cover wont go back on
the easiest way i have found to put the cover back on is to take the clutch drum off.now youn can put the cover on.reset the brake and reinstall the clutch drum.the brake loop gets in the way any other way.hope this helped,if not let me know and we can try something different.......
May 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I can't get the clutch cover back on my Husqvarna 235 e because the chain break is engaged. Spring is too tight to disengage it.
The chain brake is engaged when the brake handle is moved forward.....to ensure it is actually the chain brake...with the clutch cover off and in your hand, pull the chain brake back...if it will not move, attempt to move it forward to see if it was not engaged...if it moves forward, it is now engaged...pull back to disengage it...a lot of times the problem is not the brake, but rather the bar adjuster....if the brake is not the problem,...loosen the bar adjuster and reassemble the unit...once assembled, then adjust the bar as per the user manual.
let me know what you find.
clarkco
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 445 gas powered chain saw blade cover stuck
the only way to get the cover back on that i have found is to take the clutch drum off,after the drum is off you reinstall the cover,pull the brake back to the of possition.take the cover back off,reinstall the drum,put cover back on.it's a real pain to do it this way but i've never figured out any other way.husqvarna doesn't know any other way either.hope this helps,let me know
Apr 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
206 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
