Question about Garden
Hello, I have a 13 HP Weedeater lawn tractor. When it runs at idle at slow speed while moving it seems to work great. If I increase the throttle without moving it pulses a lot. When I run at full throttle and full speed it will pulse and shut off. If I slow the throttle while pulsing the engine will not shut off. I played with the idle screw and set it at the point of not increasing in engine speed at the minumum throttle setting. Any clockwise rotation of the idle screw and the engine runs faster. I also ran with the blades engaged at full speed at it doesnt seem to have any affect. It runs the same at full speed regardless of the blades are engaged or not.
SOURCE: Tone Pulse
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
Posted on Aug 17, 2007
SOURCE: HONDA CIVIC 1996 PULSING IDLE
It might be bad gas or a plugged filter or it might be a bad mass airflow sensor.
Posted on May 15, 2009
wadembly
  • 462 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Posted on Jul 26, 2009
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
Craftman model 917.271920 run at high speed at the time.even with the throttle in idle position
If a cable operated throttle the far end of the cable may have broken or come off. Linkage between throttle cable and carburetor bent/broken/
missing, spring broken/missing. Shouldn't be too serious.
Apr 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
Throttle on 14SZ not working, stays in low
CABLE STRETCHED..OR THERE WILL BE AN ADJUSTMENT TO CABLE SOMEWHERE...LOOK! SOMETIMES ADJUSTER IS AT LEVER..LIKE AN AUTO HOOD CABLE
Sep 09, 2012 | John Deere Garden
My bike runs rough idleing and at slow speeds. It
Check for intake leaks where the carburetor manufolds connect to the heads, when it is running at idle dpray WD40 around the area if the idle increases there is a intake leak.
reolace the gasket/gaskets,and since the carb will be off clean it or have a mechanic do it.
May 16, 2010 | 2000 Harley Davidson FXSTS Springer...
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 13 hp lawn tractor slipping in reverse and low gears
Really hard to say without looking at it but it sounds like a pully has seperated or is trying to come apart they are made in two peaces.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine revs faster than it should. no controle of speed.
on the bottom of the carb is a metal bowl, remove and clean internal parts. make sure the float moves freely and isnt sticking
Nov 13, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
