Question about E-Machines -T1840-CELERON-1.8GHz,40GB Desktop Computer System (1000000127)
This machines acts like it is in hibernation mode
This machine was knocked over, it was shut of at the time, but now when you put power to it (plug in the power supply) the fan runs, front light comes on, but won't boot, and the switch won't turn on, or even reset this machine... any suggestions?... I did check all the internal cords, cables and power plugs to make sure every thing was plugged in and tight...
Russ
  • 23 Answers
Sounds to me like a power supply problem. I would take it to a computer repair shop and ask them if they can test your power supply. They should have tools to so.
Posted on May 31, 2008
Frequently power down
1. Power off the printer and computer and then disconnect the interface cable.
2. Power the computer back on.
3. Once the computer has booted, power the Brother machine back on.
- If the computer still reboots, restarts, shuts down, or enters hibernation mode, this problem is related to the power source for the Brother machine and computer. Continue to the next step.
4. If the Brother machine and computer are plugged into the same surge protector, uninterruptible power supply, or power backup device, power everything off.
5. Unplug the Brother machine power cord from the power device.
6. Plug the Brother machine power cord directly into a wall outlet or a different surge protector strip. You may need to use the reset button on the power device.
7. Power the Brother machine and computer back on.
Still having Problem Then follow Us For Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
VPCSA does not properly go to sleep / hibernate
My advice is to shut down and unplug the Laptop when not in use. Set the Power Options to High Performance, set Sleep and Hibernate to never, adjust your Advanced Power to shut down when lid is closed. A reboot everyday resets the computer and IF there is a Power Surge your Laptop will not get fried. If left plugged in the battery COULD malfunction and become a fire hazard. Not to mention the unnecessary power applied to components and shortening their lifespan.
May 08, 2013 | Computers & Internet
Y computer keeps going into hibernation and I am trying to charge battery for the first time - will it hurt if it is repeatedly turned on and off while charging?
You might have to go into your control panel and select power settings or options and make sure you don't have the system set to hibernate. If the mp3 player is plugged into a usb port it sjouldn't affect the charging but to ensure it doesn't act out or put the usb port into a sleep mode check your power settings. Hope this helps.
Jul 01, 2010 | Audio Players & Recorders
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
Appears to be stuck in sllep mode, sr2020nx
unplug computer if necessary. Can also hold the power button in until it shuts off. Then you might want to to turn hibernation off in your power settings in your control panel.
Oct 25, 2009 | HP Compaq Presario SR2020NX PC Desktop
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
Hibernation
This doesn't sound like a hibernation problem, it sounds to be much deep, motherboard deeper, but let's rule out the hibernation. Unplug the laptop, take out the battery, this will completely shut the machine down. Then put every thing back and restart. If it starts, then disable the hibernation mode in the display properties, screen saver tab, under the button that reads power. If it doesn't start, then the problem is with the motherboard or one of it's components. Take it in for a professional diagnostic, they will be able to tell you exactly where the problem is and if it's a replaceable component.
Jul 23, 2008 | Toshiba Satellite M105-S3004 Notebook
Dell crashes and restarts upon sleep_suspend_hibernate
I'm not a big fan of using hibernate or standby, I've seen it cause too many problems, such as the one you're having. I shut my machine down when I'm done, or let it run if I'm coming back within a reasonable amount of time. I've also seen hibernation or standby create operating system errors or glitches, and premature hard drive failure. If the machine is working properly other than hibernation/standby you should shut the hibernation off and just shut the machine down when not in use. If you're getting this error when using the power button to turn off the computer, then the operating system has glitched or is corrupt and needs to be reistalled. If you need anymore help with this let me know.
Jul 01, 2008 | Computers & Internet
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
