Question about Targus PAWM001U Mouse
How can I slow down the movement of the cursor?
    Guru:
  • 200 Answers
Go to control panel > mouse > pointer options > motion > then slide to which ever speed you want
Posted on Oct 07, 2010
The page scrolls up and down - somtimes even jumps up and down - when the cursor is nowhere near the right hand of the screen where the vertical scroll bar is.
It is possible you might have picked up a virus, or a bad device driver. Try a system restore taking the computer back in time before this happened, may resolve the issue.
Mar 24, 2012 | Acer Aspire One PC Notebook
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My mouse does not works properly/ it works slow, cursor makes little jumps, movement not smooth. Laptop samsung R40
Are you using it on a mousepad? If not, that is probably why you are getting jumpy and erratic movement. Put a mousepad underneath the mouse and you should see the cursor movement improve.
You can also adjust the mouse properties such as speed and control by going into the Control Panel and opening the Mouse applet.
Do you have the correct Dynex driver installed? If not, go to the Dynex website and download the driver for your mouse. Having the wrong driver (or a generic driver) can make a difference in performance sometimes.
Hope one (or all) of those solutions helps!
Jul 08, 2010 | Dynex Wireless Optical Laptop Mouse...
Cursor and keyboard movment responds very slowly
Does the slow movement of cursor and keyboard seen only on excel? Given that your excel is not corrupted, it just could be the file size of the worksheet you are working is too big. But if the slowness is present even on small excel file, you may consider re-installing your excel.
But if the slowness is present even on other application, then the problem could be on your pc itself.
Oct 26, 2009 | Microsoft Excel for PC
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
Can i slow down my mouse cursor
Open the Control Panel. Select "Printers and other Hardware". Select "Mouse".
(Note: If you open Control Panel and it is in Classic View, just double-click "Mouse".)
Select the Pointer Options tab. (The exact tab name may differ.)
There should be a slider button to adjust the speed of the mouse. Click OK.
Thanks for using Fixya.
May 12, 2009 | Logitech Cordless Desktop S 510
While I am typing on the keyboard the cursor will skip around in my document. I find that if I do not watch closeley, my indented document is a mess. All the parts are there but they are scrambled.
A couple things can cause this to happen....
1. While you're typing, your hand or thumb might be hitting the mouse area near the keyboard which causes the mouse to move around.
2. You could have some heavy resource program running in the background which slows the system down.
3. You have an infrared mouse without a proper mouse pad so the infrared causes the light to bounce around causing issues.
4. A virus :(
Apr 02, 2009 | Dell Inspiron 1000 Notebook
Cursor movement slow and jerky
Close some application from task manager... There will be some programs running background and unecessary to us... Try it.. All the best...
Dec 27, 2008 | Adobe Photoshop 7.0 for PC
Dell ms intellimouse vertical movement of cursor
open the mouse remove the ball you should see two support shaft for the ball check whether they are rotating clean them if you can
if they rubber shield of shaft is damaged try replacing them with valve tube you usually use in a bycycle tyre
clean the transistors standing near the shaft flywheel using a soft cloth
it will be fine
Dec 14, 2007 | Dell Microsoft Intellimouse
Targus PAWM001U Mouse Logo
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
