Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I am a GM at a hotel with a Hayward H series pool/spa heater. How do I turn it back on after it has been serviced? -
  • 990 Answers
Check the gas line for a valve that could be shut off. Open the heater and check the main gas valve, it will have a knob on the top that's needs to be on. If this is the model I'm thing of it will have an on off toggle switch on the right hand side of the heater about two thirds the way down the side of the cabinet on the out side. Check all these and you should be good to go.
Posted on Oct 07, 2010
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Hayward pool heater puff back - when I turn on the pool heater, nothing happens for about 5 seconds and then the system puffs back. It has an electric spark and no pilot. The heater does not stay on from...
With a symptom like this I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Oct 13, 2011 | Hayward H-series Electronic Gas Pool...
Fixing our hotel's Hayward CSPAXI55 spa heater.
You can probally get a manuel on line if you go through Hayward.
When he took the old one out he probally just wired the circut together where the temp assembly goes into the cabnet in the top right front of cabnet in the upper panel. Then the temp probe runs around the side to the water header or manifold. If this is in the orignal spot it is on the right of the heater and easy to find. I'm not sure but if the exchanger has been turned then it will be around the back side of the header and it will be on the left side of the heater. Geting a manuel for this is a good idea anyway, good luck.
May 08, 2010 | Hayward CSPAXI11 11Killowatts Electric Spa...
Service SF
The temp probe is the metal disc in the header about the diameter of a quarter with three wires on it that plug into the back of the control board. Per Hayward:
Owner's manual.
Dec 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
HAyward H series gas heater 2500i
There is a thermistor temperature sensor beside the inlet union on the heater that goes bad, it looks line a stainless steel nut with wires on it. You can unthread to replace it and it plugs into the board behind the display. The LO means low pressure probably caused by pressure switch adjustment.
Jul 07, 2009 | Hayward Pool Products Hayward 200k Ng H...
Hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Jun 20, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward h100id1 above ground pool heater has ignition failure. ignitor allumeur won't light (less than a year old"
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Jun 08, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward Pool Heater is not working. Fan turns on, but that is it.
I had the exact same problem. The propane guy had to come back and put the regulator right by the heater instead of being on the tanks. Did this and boom heat. This was after 6 days of calling and calling hayward tech and service guy. Hopefully it will continue to work :/
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
How/where do I turn on the gas to start it
open shut off valve out side of heater and turn gas valve (inside of heater) to "ON"
May 17, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
