Question about Intel D865GVHZ Motherboard
Hello: there I just turned on my computer last night and it didn't turn on, I was thinking that the problem was my power suply so I changed it and it didn't work either. Can you please tell me if I have a bad motherbord. or my cpu just burned up. thank you for your help I'll be watting for your answer. have a good one.
  • 40 Answers
NO!! your motherboard is great... just check your power wire i think you change it or dis locate it..
just see and insure that the wire in the power button was connect properly in *********** board..
but if its doesnt work just look at all the capacitor check all capacitor.. look at each one of them
if there was a bubble.. or blown up..
Posted on Oct 07, 2010
  • luis78zamo Oct 08, 2010
    well thank you for your answer raicath_3445 but I'm sure that my power wire is connected properly to the motherboard, and also I looked at all capacitaros on motherboard and it doesn't seem to be bown up. Do you have any other suggestion?. Thank you.
Hello, After putting my computer, hp pavilion m7690n, to sleep last night. I woke up to see it was turned off so I went to hit the power button to start it up but it didn't show any power because the...
It's possible that your computer froze during sleep. First, unplug the power cord, (with the cord removed) press the power button for 10-20 seconds. PS: You will lose any unsaved data prior to sleep mode. Let me know if this doesn't resolve your problem, might be something major.
Jul 01, 2013 | Computers & Internet
Wont turn on
If your computer is in a loop boot the problem is clearly the chipset, but before being sure of it you have to disconet the memory cards and to change themfrom the slot try one at the time in slot 0 if the problem continues then 80% for sure is the chipset that needs to be changed. If your computer does not turn on then the problem is power suply, check the power suply inn maybe it is defectuose, or the starting capacitor is defective, hope tou solve the problem
Oct 22, 2011 | Acer Aspire One PC Notebook
Me harddrive is not on anymore, i left it on last night?
There was probably a power outage and you didn't notice it because you were asleep. The Computer's hard drive does not turn on by itself after a power outage.
Aug 02, 2011 | Computers & Internet
Monitor not starting up -
I think the Power Settings in your Computer needs to be changed. As whenever your computer been IDLE, it goes in a Power Saving Mode.
Adjust your Power Settings from the Control Panel "Power Options" and set them to "Balanced Power Settings" or as per your requirement. There are lot of options their to mention.
Hope your problem will be solved.
Apr 23, 2009 | Computers & Internet
Computer won't turn on
RAM faulty try reseating it or replace the ram an check
clarify ur problem more if not solved yet
pls rate me fixya if i solved ur problem
Mar 04, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
hi
check your power cable , eathing. smps check *********** bord dont touch the cabinet.i think u have motherbord grounding or your power suply of pc has pro.
Mar 20, 2008 | Computers & Internet
Unhibernating
you have to start doing a test on secuences first you have to make sure the power from the outlet to the end the cable it has 120 v ac if there is power you have to open the case to check the power suply output to the motherboard there is a power suply testers you can get that on fry'z electronics store i think thats where your problem is located power suply after you do this test post it back to see if does not fix the problem if does fix it leave your feedback
Jan 01, 2008 | Computers & Internet
Mitsubishi CS026201 TV screen problems
If the picture looked good last night
then the Tube is fine. The problem is
Power suply . I think there great tvs.
Made to last .a fair price for repair
is about 80.00-100.00
Nov 12, 2007 | Mitsubishi CS-26201 TV
Intel D865GVHZ Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
