Question about Kenmore Kitchen Ranges
DON'T KNOW WHICH KENMORE STOVE NUMBER I HAVE BUT THE OVEN ISN'T GETTING TO THE TEMP SET, THE INDICATOR SIGNAL GOES ON BUT IT IS NOT BAKING PROPERLY, TAKING TWICE AS LONG TO BAKE A CAKE AND THE CENTERS DON'T GET DONE EVENLY. ALREADY HAD SOMETHING REPLACED A COUPLE OF YEARS AGO WHEN THE OVEN WOULD JUST SHUT OFF DURING BAKING. IS THERE WAY TO REGULATE THE OVEN TEMP?
  • Kenmore Master
  • 3,361 Answers
Replace the oven temperature sensor.
Posted on Oct 06, 2010
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
115 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
