Question about XO Vision Car Audio & Video
I have a xo vision gx 7202 that has had the plug cut i need to know what each wire goes to and the proper voltage for the unit
5 Suggested Answers
  • 216 Answers
SOURCE: XO Vision GX 1236
With solder.
atdlee@netzero.com
Posted on Mar 08, 2008
Cory5468
  • 125 Answers
SOURCE: WONT PLAY DVD
Try cleaning the discs, or check the inside of the DVD player.
Posted on Mar 31, 2008
  • 1114 Answers
SOURCE: I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
Posted on Jul 01, 2009
  • 151 Answers
SOURCE: Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Posted on Dec 27, 2009
At first the screen went dim but you could faintly the picture no sound through the main speakers but wireless headphones still worked then everything went dead the disk would not turn. the red light...
looks like you have a cold solder/loose board on the power supply section of the unit.try resoldering first and post a comment how it goes..let me know ..thank you..
Feb 17, 2011 | XO Vision Televison & Video
Where can i find an adapter plug for this radio? or do i have to cut the wires for a 1994 pontiac grand/am.
You can buy a wire connector that plugs into your oe wire connector then changes the colors of the wires to match your unit. You will need to attach them to your unit by either soldering or using crimp on **** connectors. Any reputable stereo supply or installation center will have it. Just give year, make & model & tell them you are installing aftermarket stereo.
Aug 10, 2010 | XO Vision XO1915BT Car DVD Player
Dec 27, 2009 | XO Vision GX2022 Car Monitor
Does the xo vision avs 444 need a power source? and how do i power it up?
i CANNOT FIND THAT MODEL !! Is it an in dash stereo ? Or an external accesory ? XO makes SOO many different things that I need more info. Unless its a stereo unit that goes into your dash, for that you will need to go buy a clip that takes the stereos wires and turns them into the plugin for you factory stereo hole. (EG- Canadian tire, about $15 for most cars.)
Aug 16, 2009 | XO Vision Car Audio & Video
Hi I have the XO Vision GX2148 9 in. A specialist installed it for me and setup the audio to go to my FM in the car. After taking it, there is no sound anymore and the volume is stuck at zero and remote...
my xo vision gx 2148, and was installed in my car, read format vcd, mp3, cd but not read format on DVD, the manual that comes with the unit says whether to accept DVD format, I know that I do, as I get the wrong lock code (8888).
Apr 19, 2009 | Car Audio & Video
XO Vision GX-1581 No Signal
It looks like you've narrowed it down to a settings issue. If it is saying "No Signal" while on AV2, then you need to switch to AV1 where your video signal is. A remote might be available online from XO Vision (www.xovision.com) directly or on E-bay. You might also be able to find a local dealer of XO Vision from their website. One quick fix you can try....since the monitor has 2 video inputs and is stuck on AV2, you can simply get video by unplugging the video input on AV1 and plugging it into AV2. Hope this was helpful.
Sep 27, 2008 | XO Vision GX828 8" Roof Mount TFT LCD...
WONT PLAY DVD
Mar 27, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision GX 1236
With solder.
atdlee@netzero.com
Mar 06, 2008 | XO Vision 12.1 Flip-Down Monitor w IR"
XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Dec 15, 2007 | XO Vision XO-1400 Car DVD Player
Car Audio & Video Logo
44 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
