Question about Kenmore Kitchen Ranges
Eye goes all the way to high no matter what setting you put it on and will stay on high even after knob has been turned off
  • Kenmore Master
  • 3,361 Answers
The switch for that element is bad and must be replaced.
Posted on Oct 06, 2010
The air conditioner will not turn off on my 2006 Kia Sedona EX. Air blows cold, but no matter where you set the control knobs for A/C system or fan controls, air continues to flow at a constant rate, even...
If yu didn't already try, make sure your setting is not on defrost or defrost floor. This car automatically puts the setting on ac and recirculation. Turn it he setting off defrost and try again
Oct 21, 2013 | 2006 Kia Sedona
Chevy blazer heater control
So you have to separate issues here, first issue the temp staying hot. Sounds like the solenoid that runs the blend door is not working any more and not moving your blend door hince the hot air no matter the temp setting. Second is the a/c cycling on and off every 10 to 15 seconds is usually a sign that it's low on refrigerant, you need to have an understanding of a/c and the components, it is recommended to have a A/C manifold gauge set so that you can read the pressures on the high and low side of the system to get a better understanding of what the issue may be.
Oct 06, 2017 | Cars & Trucks
One heater in Samsung glasstop electric range just remains on Hi heat even when I turn the knob to low(Model FTQ352IWUX)
I believe there is an update for this range. The relais board in the back is defective. Contact Samsung abt. this and they will replace it no charge.
Apr 11, 2013 | Kitchen Ranges
Kenmore glass top electric range and the left front burner stays on high no matter what setting its on???
Hi there
Are you sure that the knob that sets the settings is securly fastened?
Or that the electronic have not got confused?
I would think that you should need to have the knob seen to.
all the best
kolbrun
Mar 12, 2012 | Kenmore Cooktops
The right hand oven lights, but no matter which gas mark setting you select, the flame does not rise to increase oven temperature, but stays on pilot settings
the flame needs to be adjusted there's a small screw right inside of the shaft where the knob goes. Pull knob off and there should be a screw inside that u shaped shaft. Turn the burners on and set the flame accordingly.
Dec 16, 2010 | Rangemaster 110 (Gas) Kitchen Range
Tappan ES 200 burner stays on high and not turning off.
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Nov 17, 2009 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
