Question about Garden
Pump won't pick up cleaning fluid thru plastic suction tube.. Troy Built with 5 hp engine
The suction tube connects to a small brass piece that has a ball valve. When pump pushes water down hose, it creates suction on the ball valve. The ball valve has to be the right size. Too large, no suction, too small, no suction. The entire world of electronics is based on similar principle.
When the ball valve wears out, or gets clogged, the pump pressure is not able to lift fluid. Try cleaning valve, but my bet is you need a new part with the ball valve.
Posted on Oct 07, 2010
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Csv 060 troy built wont start
You can prime the engine by taking cover off the air filter and removing the air filter. Cover attached by one screw. Spray starter fluid behind the white-plastic guard. Before attempting to start you must put back filter and cover. If not, the air/fuel mix will not be correct and the engine will quickly die out.
Apr 20, 2013 | Troy-Bilt Heavy Machinery
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I refill my TRansmission Fluid?
There is no reservoir...fluid is added right into the tube for the dipstick with a funnel.
Apr 20, 2010 | 1994 Jeep Grand Cherokee
My Troy Built 2500psi washer will not pump cleaning solution.
Next problem will be the spray head itself. It needs to be cleaned with a small wire from time to time.
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
192 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
