Question about Kitchen Ranges
How many amps is a plug that says D12 750? - Kitchen Ranges
  • 5,911 Answers
If this is in reference to an Ac to DC Transformer the rating indicates 750 miili amps at 12VDC.
If this is not what were referring to please post back and clarify what you mean. You posted this question under the "Kitchen Ranges" appliance category which typically use either a 220-240VAC or 110-120VAC source on a dedicated circuit of 25 to 35 amps.
Posted on Oct 06, 2010
96, ford mustang, after market radio installation help! where to plug the amp remote wire for amp
The blue wire is a triggering wire of a low amp power for Amps or a power antenna. If it draws too much power (gets hot), use a relay for more power directly off the battery.
e,g..2 amp radio output and if the amps need 1.5 amp each that's 3 amp. Need a a relay.
Jul 17, 2017 | Ford Car Audio & Video
I have a dream maker space just delivery with a 15 amp gfci plug in. Can this be plugged into a 20 amp outlet which also has a GFI on it
Yes you can plug a 15 amp to a 20 amp, but not the other way around, as long as your drawing less current (amps) then the plug is rated for you all set.
May 06, 2017 | Pool & Spa
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Would like to know what electrical amps this travel trailer uses at camp sites
Sure would be helpful if you'd say more about the trailer... like what MAKE of trailer it is, what YEAR and SIZE of trailer it is... but never mind that. SIMPLY LOOK AT THE PLUG. IF IT IS A BIG APPLIANCE SIZE PLUG WITH FOUR PRONGS, IT IS LIKELY A 50 AMP PLUG, AND IF IT IS A BIG APPLIANCE SIZE PLUG WITH THREE PRONGS, IT IS LIKELY A 30 AMP PLUG. If it is a regular size three prong plug (like you'd plug into the wall), it is a 15 Amp plug.
May 11, 2015 | Cars & Trucks
Is a champion rcj6y spark plug the same as a champion cj6 spark plug. I have a cj6 spark plug in my blower & replaced it with a rcj6y plug & it hits the piston
You answered your in question they are definitely different..a plug hitting the piston can damage or even break the piston just trying to start the blower...replace it like the one removed..good luck
Sep 24, 2014 | Garden
Interior electrical outlet plugin
Typically ' cigarette lighter ' plugs are fused with a 15 amp fuse, so in that case 15 amps is the capacity for that plug. If you have an owners manual check it for the fuse rating for the lighter plug, or check the fuse box . There may be a list of fuses and what they are for. Some folks install auxiliary plugs with higher amperage ratings, say a 20 amp circuit. This would entail using a 20 amp fuse, the correct size wire, and a plug that is rated for 20 amps.
Mar 23, 2014 | Vehicle Parts & Accessories
Cant locate the spark plugs on vw golf 88 mk1..any ideas?
I'm assuming you have a petrol fuelled car, as diesels do not have spark plugs.
Find the distributor cap leading off the distributor - it should look a little like this: http://www.google.com/images?um=1&hl=en&safe=off&client=firefox-a&rls=org.mozilla:en-GB:official&biw=1920&bih=895&tbs=isch:1&aq=f&aqi=g8g-m1&oq=&q=distributor%20cap
there should be 5 leads trailing from the cap - the lead in the centre leads to the "coil", the other 4 leads go to the spark plugs. There should only be 4 as the Mk1 was only made as a 4 cylinder engine.
Pull off the leads (though not whilst the engine is running as you'll electrocute yourself) and the spark plugs will be revealed.
Feb 08, 2011 | 1989 Volkswagen Golf
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
When plug in guitar to amp, there is either no
Try a different guitar and cord. If still problem, give the amp a bump without guitar plugged in. If amp makes noise, there is an intermittent internal connection,
Paul
Jun 07, 2009 | Roland MMP-2 2-Channel Amplifier
What amp is the plug?
This is a 220 unit and it must be plugged into a proper 220 volt plugin.
Jun 03, 2007 | Comfort-Aire RAD-183 Air Conditioner
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
