Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor blinks out for 2 seconds
My Dell monitor blinks out black for about 2 seconds and them come right back. This happens about 4 times a day. It happens most often when I am in Adobe Photoshop. But it starting doing it today and I was on the web, withouth PS even started.
  • 1 more comment
  • JoniLW May 29, 2008
    ooops. Its a Dell ultra-sharp Genisis display
    Joni
  • JoniLW May 30, 2008
    I don't do anything. I get a screen freeze, and then it just winks out (goes black) for about two seconds. When it comes back on, I have all this underlying screwed up pixels in different places. Usually in a straight line from where a window was.
    It sometimes winks out within the first 10 min its on. Sometimes it takes an hour or two. But it continues to do it about... 4 - 6 times a day.
    JW
  • Damon Gray
    Damon Gray Mar 02, 2009
    For me, this happens in the morning when I first fire it up. Dell Optiplex 745. It will continue for about two hours. The effect is the same as when you install Winders, and it is looking for new hardware. The video will "blink out" for a couple of seconds three or for times. Only the secondary display. Swapped monitors, but no help. Changed video cards, no help. Upgraded ATI drivers. No help. It almost behaves as though there is a bad solder that begins to lose contact as the machine warms up. In my case, it will happen from about 6AM to 9AM and be fine for the rest of the day. We are required to power down at night. Next day, 6AM we start all over again. It is doing it as I type this.
    Sergeant:
  • 458 Answers
What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Posted on May 29, 2008
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E172FP, monitor blinks then goes blank or black
This is a known problem of the Invertor board.If you are technically able you can open the monitor and resolder transistors 2sc5707 as also all pins of 4 yellow invertor transistors that you can see near the backlight connectors.
Samir.
Please rate the solution and provide feedback
Sep 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Aug 14, 2008 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
94 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
