Question about Oster Kitchen Appliances - Others
Do you work on toasters? after cleaning toaster, heating elements not all working
    Champion:
  • 248 Answers
Wiring may have gotten wet while cleaning try using hair dryer,blow through all the vent holes for a few minutes
Posted on Oct 07, 2010
Falling Down
  • 67 Answers
SOURCE: Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Posted on Nov 30, 2007
cactus bob
  • 267 Answers
SOURCE: "Outside" heating elements don't heat up. Can I find replacements
its not the elements . its the control board . and you cannot buy a control board , but it can be fixed there is a small relay on the board that needs to resoldered to the printed curcit board . its a pain the the rear-end to get to it , fix it and get back in there and all back together but it can be done ( about 3 hours total ) , if your like me and never say never ......... good luck
Posted on Feb 19, 2009
  • 464 Answers
SOURCE: I have a Phillips toaster. It has been working
it sounds like the magnetic coil which holds the lever down to the toast position has burned out. you probably can't get the part for repairing it as it would be too costly
Posted on Oct 04, 2009
espressonist
  • 1711 Answers
SOURCE: I changed the element in my Dualit toaster; still doesn't work
If I understand well the blackened wire is an overheated wire which it is probably but off in one point so no electricity comes to the element anymore.
However overheated wire in you metalic toaster is a very danger thing to have and need to replace all the wires you have noticed that they changed color or not look good contition.
The problem have been caused from a problematic element which is the one you have already replaced.
However you if after you replace the wires you need to inspect the toaster after some time in order to be sure that not any other element causing the problem.
Good luck.
Posted on Apr 02, 2010
espressonist
  • 1711 Answers
SOURCE: I have a 4 slice
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
Posted on Sep 15, 2010
Kitchen aid toaster won't stay down, heats when held down, but only on bagel setting. Checked crumb tray but all clean. What to do?
Contacts may be coated with Burt oil, butter, other matter. When engaged, contacts aren't engaging.
Aug 31, 2014 | Kitchen Appliances - Others
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
The heating elements don't come on.The timer is working as you can hear the clicks but that's about all.
We had the same problem. I took off the bottom plate, cleaned the toaster, reseated all of the connectors on the heating plates, timer, and switch, and the toaster started working again. Only one connector was slightly loose (but it was still connected with decent contact). I am not sure what fixed it. If that did not work, my next step was to purchase replacement parts online and swapping out the switch, timer, and heating plates (in that order).
Feb 11, 2010 | Dualit CTS4E 4-Slice Toaster
How do a toaster heatingelement work
The toaster heating element converts electricity in to heat energy through the process of Joule heating effect. the electric current flowing through the element encounters electric resistance, resulting in heating of the element.
Sep 13, 2009 | Kitchen Appliances - Others
Toaster Oven's top heating element is not working... repair?
Thrash it.
They are not meant to be repaired because the lawyers told them there is too much risk.
Mar 11, 2009 | Black & Decker Toaster Ovens
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Toaster will not heat
If your timer works but no heat and you think you may have goten water inside the toaster area.. chances are you've dislodged the heating element itself. If you shorted it out, you would probably take out your circuit breaker or fuse from the receptacle that provides power. If you are relatively handy, UNPLUG it, then look at where the heating element penetrates the oven compartment to see if it looks normal ( meaning that it is passing thru the wall of the oven ok) then check the other side ( you may have to remove a cover) to see if the wires providing power to that element are still attached. To be honest, I do not know this particular brand that well but it does sound like a fundamental problem that should be easily addressed. Good luck..
Sep 23, 2008 | Dualit CTS4E 4-Slice Toaster
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Kitchen Appliances - Others Logo
108 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
