Question about Singer 3116 Simple
Singer machine the needel thread will not wrap around and catch bobbin thread
    Genius:
  • 1,788 Answers
Watch your video again and read your manual, it may simply be the way your needle is inserted wrong, flat side should face the rear of the machine.
Posted on Aug 15, 2010
Hand wheel is binding - seems to be a problem with the plastic gears inside, but I don't see that there are any warn spots on them or on any belts. Any suggestions?
First, take a look at page 68 in your user's manual. If you don't have it, you can download it free at the Singer Sewing machine site. You can (and periodically should) remove the face plate over the thread path for cleaning and oiling. There are probably threads wrapped around a part there, and in addition, you can take a flashlight and look to see if there might be threads underneath the bobbin winder preventing the machine from moving.
More rarely (but possible) there may be threads wrapped around the gear underneath the bobbin basket (holds the bobbin case), so you ,may need to remove the base to access that part, but it's generally not a difficult process.
While you are there, it's probably time to use a little sewing machine oil and lubricate the parts, as per your user's manual.
Jun 27, 2015 | Singer 57815 Mechanical Sewing Machine
My sewing machine thread is sticking around the drop feed control
There are several possibilities, but the most likely is you have a burr on the needle plate that is catching the thread. Run your finger over the plate, and if you feel a rough spot, use an Emory board to smooth it. You can also easily replace it. Sewing Parts online has a replacement plate for $12.99, by the way, and I'm going to provide the direct link below.
Another possibility is the bobbin is not correctly wound, the bobbin case is not correctly inserted, the surface of the bobbin case has a rough spot (solve an Emory board the same way), the needle is not all the way up in the clamp, you did not thread with the presser foot UP, or your bobbin is warped. To determine that, roll it down a flat surface. If it wobbles, it's warped. Needle Plate Singer 416472401
Oct 02, 2014 | Singer Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Sewing machine dressmaker model 300z
i think you have not looped the thread around the tension on the top before putting it onto the bobbin. you need to wrap the thread in a circle around the sphere near the regualr threading lines.
Nov 10, 2008 | Singer 7462 Mechanical Sewing Machine
Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Singer 30920
Bobbins are specific to machines.........if you are trying to use a non-singer bobbin, the diametre and depth may well be several millimetres different and will result in what you describe.
Ask for plastic singer bobbins for a top loader......if you contact Singer or an agent, they will give you a part number and will probably ship to you as well.........get a few and have all your colours ready, not all layered on just a couple !
Bargain Box
Jan 27, 2008 | Singer 1120 Mechanical Sewing Machine
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Oct 27, 2007 | Sewing Machines
Singer 3116 Simple Logo
82 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
