I have a cable modum with a wireless router and I am not connecting to the internet - what do I do?
  • Doctor PC
    Doctor PC Oct 07, 2010
    Specify the Router brand?
    Sergeant:
  • 235 Answers
First make sure your modem is turned on and the lights are on. Next make sure your router is on and it's lights are on. Also make sure that your router is connected to your modem. Then make sure that your wireless adapter is on and that the drivers for it are installed on your computer and your computer recognizes the wireless adapter and the wireless connection.
You did not specify brand or model of modem or router so at this point this is the best I can do.
Also what type of wireless adapter you are using and what kind of computer. Again this goes back to brands and model numbers. If the above does not help, come back with more specifics and I'll be glad to try and help you again. good luck!
Posted on Oct 07, 2010
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I have the Zyxel ES-105A connected in the following way: LAN cable from modum connected to port 1, LAN cable from port 2 connected to my laptop which I use to log in to my modum and LAN cable from port 3...
If your modem is not also a router you can only connect one device to it. You should have a router instead of a switch. Otherwise check the settings on your modem to be sure the ports are open that are needed for the Sling Catcher.
Apr 04, 2011 | Zyxel ES-105A (ES105A)
Hooking D-Link 655 to a Ambit Cable Modum with Charter Cable, Cannot Get it to Configure. When modum is directly plugged to modum internet is fine, but I cannot get throught he setup stage when hooking the...
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
Sep 24, 2009 | D-Link Computers & Internet
Router hooked to modum no wireless light can access internet from cable but not as a wireless system Belkins F5D-8233-4v3
You can switch wireless on/off
Download the manual from here
http://www.belkin.com/support/articl...=8340&scid=942
starting at page 42
check out page 43
and see what the setting is on your router
Aug 07, 2009 | Belkin Computers & Internet
Internet connection
HI
Are you connecting using a cable or wireless. Also post the ip address that you are getting. To get ip
start-run-type cmd-in the command window type ipconfig.
also post the firewalls or antivirus programs that you are using.
thank you
rakesh
Jan 07, 2009 | Siemens SpeedStream 2604 Router (obss2604...
Modum
You do not have to use the cd.
Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 30, 2008 | NetGear WGR614 Wireless Router
Cnnecting to cable modum
To access your router you should goto http://192.168.0.1 - It should explain in the manual.
You may have to set the router in Cable Modem mode as it may be in DSL mode now.
I hope this may help.
ALSO! There should be a little hole in the back that you can put the tip of a pen into to press a button and it will reset the router back to factor defaults. Default settings would be cable modem mode. Be sure to have the router powered on and press the button down for 10 secs and notice the lights on the router should flash. After that power down the router, by unplugging the power and the plug it back in. It should be set back to factory defaults.
Oct 23, 2008 | Linksys Wireless-G WRT54GS Router...
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Jun 03, 2008 | Linksys Wireless-G WRT54G Router
Actiontec Wireless Router not providing internet connection
hi firend
there thats the way but if u have wireless connetion in your router & if u have wireless in your laptop then u can use easy in your home
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
