Question about Briggs & Stratton Garden
How do i put oil in my pressure washer and where thanks
Gasoline-powered pressure washer needs oil in two places. The pump and the engine.
Please read your manual along with this information.
Also stop by small engine shop and double-check details.
First the pump: Pump is where you attach hoses.
-On side of pump is clear window you can see oil. Oil should fill about half way. Do not fill entirely.
-Open cap on top of pump.
-Pour oil in from top.
-Your manual should tell you which oil to use. 10-20 or 10-30 non-detergent should do.
The engine.
Look for oil cap on lower side of engine
Use regular 10-W-30 motor oil.
Don't over-fill. About half way up dip stick is about right.
Never turn gasoline engine upside down to drain oil, or oil will flow into carburetor.
Posted on Oct 07, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
What type of gas does it take
Is this a big power washer as shown in the photograph?
Is there a separate place to put oil for engine and pump?
If your engine has a place to put oil, then the engine takes ordinary gasoline
If you have a small engine like a weed-eater or chain-saw, and there is not a separate reservoir for oil, then you mix 2-cycle engine oil with the gas in a 40:1 ratio
Pressure washer oil:
Pump fills about half-way up with SAE20 or SAE30 non-detergent motor oil
Engine fills half way up dipstick with 10-W-30 motor oil
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
May 24, 2010 | Karcher G 2600 VH Gas Pressure Washer
Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Pressure washer with 5hp Honda will ONLY run with choke on
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
Aug 10, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
481 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
