Anytime either of my cd drives is in use the computer shuts down. Power supply?
    Master:
  • 388 Answers
Try diconecting one drive at a time it sounds to me the psu (power supply unit) isn't man enough and may need to be upgraded.
Posted on Oct 06, 2010
2 Suggested Answers
Jmizpah777
  • 290 Answers
SOURCE: computer shuts off randomly
i suspect that there could be driver issues on your system that made your computer to shutdown, if you stil changed your power supply, and cd drive, then there might be a problem with the cable that you are using or the slot from your motherboard. If you install the cd drive you should check first from bios if it can be detected. Is your drive an IDE or SATA?
Posted on Jan 10, 2010
My pc is shutting down and I can't wake it up without shutting down the power from power supply. The Antec 300 tower has two blue lights- the top light starts blinking when it has shut down and I
sounds like a power supply problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps
Oct 13, 2012 | Antec Computers & Internet
Computer shuts down on it's own. It will try to re-start but immediately shuts down again
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 04, 2011 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Power supply to my Inspiron 1525 shows green but when I plug it into the computer, it turns off. Computer will not start at all.
possibly a bad/faulty PSU power supply unit or its leads your computer might be shutting down to protect it from damage test all the leads that are attached to your hard drive from your motherboard and all of your drives cd/dvd 3.1/2 floppy including electrical extensions or just replace them they might be bad/faulty
hope this helps
Nov 28, 2010 | Dell POWER SUPPLY Power Supply
Shutting down almost instantly when powered on, sometime runs for ever , then on a restart it just shuts down. anytime i hit restart it shuts down wont start up again unless i power it completely off...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
Nov 17, 2010 | Acer Aspire L100 PC Desktop
What would make my motherboard just 'shut down'? The little green light comes on on the motherboard, but that is it. No fans spin, no HDD spin up. I tried a different power supply, didn't work. I took...
One bad/faulty lead can cause a computer to shut down
test or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 24, 2010 | Intel D945GTP Motherboard
Computer shuts off randomly
Jan 10, 2010 | Dell XPS 410 PC Desktop
Computer shuts down on inserting disc
I have just fixed a computer with a similar problem. The owner installed a new DVD burner (a SATA drive) and every time he inserted a CD or DVD disc, the computer shutdown (mostly, because the front LED was still on and the CPU fan too, everything else just turned off [drives, PCI cards]). It happened in Windows, in Linux (Ubuntu) and even in the BIOS screen, so I discarded an OS problem. Also happened while booting if a CD or DVD was already inserted in the unit; as soon as the drive LED blinked, the computer crashed. After checking the obvious, I did three final tests:
1) try the DVD unit in another computer (it worked);
2) try the DVD unit with the power connector only, with the data cable disconnected (it shutdown);
3) try the DVD unit with the power connector from and external power supply, with the data cable connected (it worked).
By this point, it was obviously a power supply problem. I checked the power supply unit (PSU) and discovered it was pretty small (250 W). So I installed a more powerful one (350 W) and then it worked.
I checked with a wattmeter and it seems this DVD drive increased the power consumption by 25 watts when started to spin the disc. I really don't know if that is normal (taking 25W to start spinning the disc) or if this drive has some defect, but it seems the previous PSU could not provide that extra power and shutdown some of its output (but not all).
So, if you have this weird problem, maybe checking the power supply and testing with a bigger one may help.
Regards,
MV
Jan 31, 2009 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
350w switching power suply
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Jun 26, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Orange flashing lights
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Mar 18, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
