My ice maker gets water, makes ice, but the arm rises on its own and remains extended as if the ice bucket was full and I constantly have to lower it so that the ice can spill into the bucket. How do I get the arm to remain down until the bucket is full and not extend itself which stops the ice from dropping into the bucket?
If you are a real DIY'er, remove the ice maker from the frig and see if the arm has or had a spring return down or check its position with the cam that operates it as it goes around.
There is a screw sticking out from the right side of the freezer wall that has a grey plastic spacer around it that acts as a stopper for the ice level arm. I have seen the ice level arm get stuck on top of this stopper before somehow. you just have to carefully bend the level arm around it and move it below the grey plastic stopper. If it is not stuck above that but the arm still will not come down, then the only other solution is likely a new icemaker, as the arm is geared internally to the icemaker to rise and fall as the ice is made.
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Check the shutoff arm, the shutoff arm fails to move upward when the ice bucket
is full.
Check
the water pressure. If there is not
enough pressure, the ice maker will not have enough water to make ice.If
water flow pressure is good, check solenoid valve activate and also
it's cleaned.
Locate your ice maker, remove the ice bucket. Pull the cover
off the end of the ice maker. Locate the holes "V" and "L". Take a paper clip
(jump clip) and tape. Straight the clip and put tape in middle. Hold the taped
side and insert the clip into "V" and "L". This sends the power to water valve.
If water goes into ice-maker, water valve is good. If notreplace solenoid.
Check
the freezer temperature. The proper freezer temperature should be around 5
degrees. The warmer it is in the freezer, the more difficult it is to make ice.
thanks, helpful?
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
The ice bucket is probably cracked we have had three that have all done the exact same thing all different name brands. Just order a new ice bucket. Good Luck and my advice is to purchase a extended warranty on these because its not a matter of if it will break its when. Edgestar lasted the longest it lasted 1yr and 7months.
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
