Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven won't ignite. The broiler does and the top works fine.
  • 5,911 Answers
This problem is commonly attributed to a bad igniter on the bake manifold in the bottom of the oven. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in most ovens each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Posted on Oct 07, 2010
Why are broiler and oven not working? KitchenAid Slide in kgss907sss00
Check the gas regulator. I would have a professional do this though.
Dec 28, 2015 | Kitchen Ranges
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
