Question about GE Refrigerators
Have ge refrigerator model TB15SLBLAD that runs continuous at any temperature setting
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ..,,
Posted on Oct 08, 2010
Why my side-by-side refrigrator is not cooling and freezer is warm too.
Check your compressor if overheating.
Observe the running condition of the compressor.
Check if your compressor is running. If compressor is running then you have a freon leakage or insufficient freon.
If not check your thermostat if working properly. (Get a multi tester and check for continuity. at normal temperature the circuit should be closed)
If thermostart is working properly then check your OLP(over load protector) which is attached to your compressor. it should be closed circuit.
Aug 12, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Model TPH 21 PRSM WW does not turn offf
Many things that could cause the problem First if you just plugged it or have little in it, it will run for a long time. Next check if if it is cooling properly place a thermometer in a liquid it the refrigerator compartment it should read around 42 degrees. If it is warm in the refrigerator compartment Look at the freezer back wall for frost buildup If you have frost on the back wall, you will need to defrost it and repair the defrost circuit. This is a. Common problem on GE models If the temperature is good in the fresh food compartment you will probably need to replace the thermostat or cold control
Aug 01, 2014 | GE Refrigerators
I have a GE monogram refrigerator model ZFSB26DRSS. Yesterday the freezer stop working (set temperature 0F, reading temp 30 F). In the morning the refrigerator got warm too (set temp: 37 F, reading...
This sounds like the compressor is not running. Causes for this happening on your model can be caused by defective start relay, run capacitor, defective fan motor and defective motherboard. The part number for the motherboard is WR55X10942
The repair is rather complex for most people on your model and I will be glad to go through how to do this if you like. Let me know and I will walk you through the repair, Thanks
Sea Breeze
Apr 09, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
THE VEGETAGLE, FRUIT STORAGE PART OF MY SIDE BY SIDE GE MODEL PSS25NGM REFRIGERATOR IS TOO COLD. I SET TEMP FOR 37 AND GET 29 20 30
The thermister located inside the wall of the fresh food compartment under a small ribbed cover must be faulty. The system telys on capacitances changes in the NTC(negative temperature coefficient) If the NTC is faulty then the dbrain will continue to send cold air into the fresh food compartment. I have a service tech's repair manual for a late model GE ice box right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 28, 2010 | GE PSS25MGN Side by Side Refrigerator
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
