Question about Mitsubishi WD-Y57 57" Projection HDTV
Just replace the lamp.. there is a burning like smell, does anyone know what is causing this smell?
  • Mitsubishi Master
  • 8,457 Answers
After the projection lamp was replaced the tv work fine right?The burning smell,is the burning carbon from the dead projection lamp.
Posted on Oct 06, 2010
  • laram Nov 22, 2010
    It smells after the new lamp was installed. Let it stay on for awhile but the smell continues. Every time I turn it on. Only takes a couple of seconds till the house smells. Have to shut it off after a couple minutes because the smell is too strong.
  • Dianna Dec 22, 2012
    i have an Thomson 50DSZ644 with the same prpblem. here after replacing the lamp some hourse was the picture fine. but next day i turned on the tv AND IN THE MIDDLE IT STAY VERRY DARK.
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
Head lamps are burning out one at a time,first low beams then then high beams ending on the left side,smells of burning plastic inside the vehicle.
check voltage of battery while vehicle is running if over 14 volts replace voltage regulator high voltage would cause this problem
Nov 25, 2010 | 1996 Ford Explorer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Burning smell
The lamp is overheating some plastic fitting etc?
Feb 19, 2010 | Sharp XR-10X Multimedia Projector
Horrible burning smell from lamp
If you ordered it directly from sony then i would be concerned and contact the to have it replaced under warranty. If you did not get it directly from sony I would expect it is a rebuilt lamp or you purchased just the lamp part instead of the whole cartridge and installed it into the carttridge yourself. The lamp is designed to be replaced as a cartridge . The smell is probly a lamp that is burning the wires on the back side of the lamp because it is incorrectly inserted and the wires are touching the glass. Just a couple times i have seen a lamp that will smell slightly as the plastic and insulation heats up for the first time.But it only smells a little for like a day.
Oct 15, 2009 | Sony 50 in. HDTV Television
I replaced the bulb on my Samsung DLP projection TV (HLT5075SX/XAA) but now there is a plastic burning smell. Does anybody know what it can be?
That is probely the smell of the new lamp. If the odor persist and gets worse then remove the lamp and inspect it and the inside of the tv.
Jul 08, 2009 | Televison & Video
Smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
Jan 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi WD-Y57 57" Projection HDTV Logo
1,913 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
