Question about Danby Dehumidifiers
Hi I have a Danby dehumidifier DDR6510E and it shows error code P1. This then does not allow any control changes such as fan speed or humidity setting. What is this error code???
SOURCE: Danby DDR255 Dehumidifier
only works when on fan setting why i have a musty smell that I need to get rid of model ddr255 serial 0402040704525 help..
Posted on Oct 24, 2008
  • 12 Answers
SOURCE: P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Posted on May 22, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Posted on Jun 14, 2009
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Posted on Jul 20, 2009
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
How do I get my Danby dehumidifier, model#DDR70A2GP stop its fan from running continuously once it reaches a desired humidity level? Thanks
I just read your instruction manual for you, and it appears that you can't. You choose the humidity setting and you choose your fan speed and that's it. The machine will stop when the bucket is full.
Your manual is here;
http://www.danby.com/cms/documents/pdfs/en/DDR50A2GP_DDR60A2GP_DDR70A2GP_DDR60A1CP_EFOM_%28DM%29_Revised_Feb_27_2013_%28web2%29.pdf
Sep 12, 2015 | Danby Dehumidifiers
My Daby dehumidifier will sometimes have coade P1 show up on LED readout and also go to high fan. I have it in basement and set at 50% and low fan. What is the problem? I have to disconnect and reconnect...
don't know what the P1 code means, but maybe your demand of 50% and low fan is not able to be achieved so the unit will increase the CFMs (high speed on fan) to try and reach the 50% humidity level you are asking it to do within a certain time period.
Jun 11, 2011 | Danby DDR607EE Dehumidifier
The fan is running on my dehum but it cl ollects no water. a code P1 appears in the window now.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 23, 2011 | Danby DDR2509EE Dehumidifier
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
E3 error code on danby dhcc6020, its new out of box. tried danby service rep. , cant get a response back from them. any ideas on how to fix?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I had called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Danby Service Rep. helped me with my question about my P1 code (for DDR657EE).
Apr 11, 2009 | Danby DHCC6020 Dehumidifier
P1 error
E2 = Not draining
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
E2 = Not draining
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Dehumidifiers Logo
271 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
