Question about HP Pavilion dv6000z Notebook
I update bios hpdv6 but shutdown and restart with black screen no data the fan cpu work
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
Check if your system registry is cleaned and have no corrupted registry entries, its better to run intel software aprtner, reginout scan http://www.reginout.com
Posted on Oct 10, 2010
I update my motherboard bios then restart. CPU fan running but monitor still black no display.. i try clear the bios bu t still dosen`t work.. what should i do?
You need to flash your bios to an earlier version and see if that fixes the problem. What may have happened is you might have updated it to a version not supported by some or all of your hardware, I recommend putting it back to the factory default BIOS.
Feb 04, 2011 | Gigabyte GA-VM900M Motherboard
Tip
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
No POST/Black Screen
Believe it or not, clearing the CMOS might actually help. Make sure you do it right by completely unplug the power cord or turn off the PSU, then take the battery out.
It also sounds like the CPU might be too hot. Look under the fan of the heatsink and see if there is any dust that will block the airflow. When the computer is on, touch the heatsink and feel if it is really warm. If it is really warm, it's a good sign, you might just need more airflow. If it is cold, you might need to reinstall the heatsink/apply new thermal compounds.
Mar 07, 2010 | Gigabyte Computers & Internet
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Blue screen error and intermittent restart issue
before you update bios, sounds like there is a problem with something getting hot inside your computer. check, proccessor fan. make sure it is working properly and the heatsink is attached correctly. other to check is video card, if it has fan on it, make sure it works. sometimes if you add an extra fan to blow out hot air from case it helps. the computer will go to shutdown if it senses high heat on any of the components on motherboard.
when you resolve this then goto your motherboards manufacturers website and download latest bios upgrade, usually is a self executable file. run it after save to your computer and it will upgrade your bios.
Apr 14, 2009 | Computers & Internet
CRITECAL PROBLEM .
you could of:
A: Blown your CPU.
B. Blown your RAM.
One of them have to replaced. I suggest you try the RAM first cause it is the cheapest. if you can't do it, have your local PC shop take care of it.
Jun 11, 2008 | Computers & Internet
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
SUDDEN SHUTDOWN
I am Vikram Kumar Thumu from India-Hyderabad. I would like to provide you my suggestions on this issue for you...
Well, this issue could happen only due to below three reasons....
1. If the Hard Disk Drive is bad.
2. If RAM card is not working properly.
3. If there is an error with Operating system...
However, to isolate and to resolve the issue I recommend you to perform below solutions and try out. I hope that this should resolve the issue for you.
Solution 1: BIOS UPDATE OR BIOS FLASH
Note**--- THIS BIOS UPDATE IS APPLICABLE IF YOU ARE USING WINDOWS XP.
NOTE**-- If you are ready to perform BIOS update, please connect the Notebook with Ac Adapter and make sure that Battery is also installed for Notebook.
Please open below link in the new Internet Explorer web page...
The web page titles as " WinFlash Utility for HP Notebook System BIOS; Windows-Based"
Link is:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-39816-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Once if you open the web page, please click on the option " Download Only" and then try to save the download file on Desktop and run the file after download is completed.
This should successfully install the BIOS Update. However, if the issue still persists then please perform next solution
Solution 2:
In this solution we will check the functionality of Hard Disk Drive...
Please restart the Notebook, while it tries to boot up please press F10 key, this should get into BIOS screen or ( SETUP UTILITY ) screen.
In the BIOS screen please locate to the Tools or Advanced Menu, and then select the option HARD DRIVE SELF TEST. and go ahead with testing the HARD DRIVE SELF TEST.
Once if test is completed, it reports a message of the status on Condition of Hard Disk Drive. If you receive error message then it confirms that this is an issue with hard Disk Drive. then you need to replace the Hard Disk Drive for your Notebook.
Else if it reports success, then it confirms that Hard Drive Drive is perfectly alright..
Then only possibility that is left is " Error with Operating system"..
if you found that it is an issue with Operating System then please go ahead with reinstall of the Operating System for your Notebook PC.
This should resolve the issue for you...
If you need any further assistance on this issue, you can mail me at thumuvikram@rediffmail.com , I'll be glad to help you further on this issue.
Bye..
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Sony Vaio pcv-rs 312v
check whether your SMPS fan is running the back side of the cabinetand also the cpu fan if you can open the system case. if the both fan is running fine then rmove the CMOS battery and start the computer after 2 or 3 sec the cpu fan will stop that means BIOS is cleared reinsert the battery and boot the system go to BIOS and go to load default setting and enter(press DEL or f2 to enter BIOS) after that press f8 and go to safe mode (not work with win98)it will take some time,after getting in to the OS scan your computer for virus with best and latest updated ANTI VIRUS. let me know whether it is working ot not. if not working kindly let me know what the exact problem is write all the process you follow to start your PC reply me soon
Oct 07, 2007 | Sony VAIO PCV-RS312V PC Desktop
HP Pavilion dv6000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
