Question about Sharp AL 1631 Copier
LOUD Woodpecker noise
When I turn the machine on it makes an extremely loud woodpecker-style noise- I called Sharp support and they had me go in to program and manually force it to try to run without toner or drum in unit and it still made the loud noise so problems with those can be overruled, also the machine is set to unlock so no issue there. They told me to send in for service for over $250!!! Anyone know what it might be and if there is a quick fix? I haven't unscrewed the paneling yet but wanted to see what some suggestions might be first. THANK YOU!
  • CharlieGreen Jun 14, 2008
    I have the same problem with a Sharp AL-1631. I opened up the drawer to place more paper when still making a copy. After this, I got the LOUD Woodpecker noise and cant use the multi-bypass tray. I still get copies using paper from the drawer, but the noise is still there. I looks like a gear is rotating and hitting a plastic part. The noise comes from the multi-bypass tray and side cover.
    I tried the following but the noise is still there and cant get copies from paper loaded in the multi-bypass tray:
    1. Turn off/on.
    2. Copy without the paper tray.
    3. Copy without the TD cartridge.
    Is there any solution for this?
I have the same problem with one of my clients copier and I open the machine from the by pass tray and the clucth from one of the gear there is a spring that it is broken the spring is cover by a housing tube it is very simple to fix but tidues to get to it they don't sell this part
Posted on Oct 20, 2008
The fuser drive gear on the main drive unit is worn
Posted on Jun 18, 2008
    Problem Solver:
  • 5 Answers
The main motor needs relacement nylon gear mounted on steel shaft is cracked and not turning but motor is
Posted on May 29, 2008
Woodpecker problem
Since this question is in the Washing Machine category, I would tie a string to the lid of the washing machine, and put woodpecker food inside it. When the woodpecker flies in to get the food, pull the string and the lid ill close, catching the woodpecker.
Jun 13, 2015 | Washing Machines
Make extremely loud noise when you first turn it on and it heats the water and again after each cup of coffee
This the water pump when is working. It should make loud noise. In extreme case in very loud but after a while it become less loud. If just consider that other smaler models have a smaler pump which is silent pump but they dont have it work always so in you case you a very good coffee result.
Jul 10, 2010 | Keurig B100 Coffee Maker
My bikes been sitting for about two weeks and now it won't turn over. It makes this woodpecker noise.
charge the battery and make sure that the connections are tight and clean at the battery. Good luck and thanks for using
May 19, 2010 | 2002 Harley Davidson FXST Softail Standard
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Woodpecker-like noise when I try to start the car...
the noise is from the solenoid but the battery is very weak or the connections are dirty or loose clean and tighten connections charge battery if this dosent work you will need a new battery
Jul 03, 2009 | 1997 Toyota Tercel
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Truck won't start, lights, gauges, radio works, loud clicking ( like a woodpecker ) noise coming from down under engine area
sounds like your starter has a dead spot. time to replace. you can try to get it going by having someone hold the key in the start position and tapping the starter with a small hammer. Just make sure the truck is in park and has the hand brake on for safety. If this works, you just saved a tow charge.
Aug 04, 2008 | 1988 Ford Ranger
Woodpecker noise II
A lot of times when this happens those grears need to be replaced. If you find a Sharp dealer in your area, they shold be able to fix it for you.
Jun 17, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
235 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
