Question about Bloomfield 1012 Coffee Maker
Sparking when I hit brew
When I hit the brew button there was a big boom and spark. It continues to spark every time I push brew.
  • peterwolfe May 29, 2008
    It is an older machine and I don't think that it has a circuit board. It very well may be the relay though.
  • 868 Answers
This is a short that is stemming from your circuit board to start relay.Your  going to have to take apart this and remove the board and relay inside.
Posted on May 29, 2008
  • 298 Answers
I suggest you already have it checked. if you getting a spark (if its like a electric spark) if you hit brew, I dont think that its normal.
Posted on May 28, 2008
I have a 1996 RAV 4, but it won't start when the air is damp or it has been raining, it only starts when we've had a few dry days, & although I don;t drive it when started, if it's damp again the
no mileage state, nor from last full tune.
it needs a tuneup this decade.
oldest story on earth (cars) (bad spark)
no ignition parts (high voltage) last the life of any engine,. 300k+
so we do what is called a full tuneup at about 60,000 miles.
also called doing the 60k service point list.
open glove box, take out operators guide, yes, really
turn to the 60k page. bingo.
high voltage breaks down all the insulation,
over time.
all.
even your power company must do this. or BOOM,
Have 2 dead friends from BOOM. 17kv distra. systems.
no engine stated so can not be specific.
my guess, is tghis.
The third-generation 3S-GE was produced from 1994 to 1999.
1996 is a big change year, OBD2
and from Distributor spark to none, at Aug, 1996 they swiched
to the DIS system. with a wasted spark coil pack only.
replace the HV wires, and spark plugs.
end story.
if the scan tool shows, P030x errors. fix X
if x is 2 cylinders it might be a bad coil pack,(last thing to replace)
there are 3 spark systems , at this evolution
Distrubutor with internal coil.
wasted spark coil under TB, with 4 HV wires.
and coil over plugs, later, called COPS, 4 coils.
yours may be wasted spark system with 4 HV wires,. replace them.
show a photo of the engine, and i can ID it. in 1 second.
good luck.
Dec 07, 2014 | 1996 Toyota RAV4
2008 fatboy
how good is the magneto on it? just a guess but it does create the spark
Sep 19, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Ignition continuous spark
I am not familiar with this model, but in general when it says to push the button it will start the sparking sequence to lite the pilot or burner once it lites and proves flame then the sparking should quit. Something must of broken and is keeping the spark staying on. It should not be sparking all the time. Hope this helps.
Jan 30, 2014 | Heating & Cooling
Engine will not start
cranks but dont start (do not run car with low coolant, if freezed never forget 50% coolant ratio. or boom. cracks in engine.
do you spark at all cylinders.
google checking spark 1mil hits.
Nov 21, 2013 | 1993 Honda Civic 4 Door
Can a back fire cause motor to jump time
if its a twin cam maybe ..sounds like a bent/burnt valve/////try easy stuff first like spark plugs...wires..battery..you need 12.6 volts to run and charge
May 02, 2013 | 2000 Harley Davidson FLSTC Heritage...
Silvia keeps brewing after shutting off
maybe cooffe termostat is bad and overheating
Aug 23, 2009 | Rancilio Silvia Espresso Machine
Cannot light
some times the wire for the ignitor will get burned inside the chamber, if this happens you will not get a spark and will need a tech, but turn the gas valve to the piliot position hold down the button on the gas valve while clicking the electric ignitor button, look thru the site glass towards the left side of the burner assembly while doing this, if there is no spark it will have to be taken apart and replace the spark ignitor, not a big job you just have to make sure the seal on the burner cover doesn't tear or get damaged
May 03, 2009 | General Electric GE SmartWater Household...
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Bloomfield 1012 Coffee Maker Logo
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
Kelley Hopper
frankecoffee
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
