I have a kelvinator furnace M#G6RC 060C-12A The indicator light blinks red twice and the code comes back as pressure switch is open with reducer on. Can you please help
burzerko
  • 254 Answers
SOURCE: furnace won't kick on
Downstream of your fan discharge there is a little plastic assy. most likely that will have a pickup tube and a piece of vinyl or latex tubing attached. First check to make sure that the pick up tube and/or tubing does not have a restriction. If it is clean use an ohm meter to read resistance across the switch to verify it is operating.
Posted on Nov 15, 2008
  • 306 Answers
SOURCE: armstrong air tech 91 furnace problem
Sounds like the flue is plugged, I had same problem and opened up the draft fan and there was a dead bird restricting the flue. Furnace will never light if the pressure switch never closes as you have found out. Also has anyone moved the switch some are position sensitive meaning have to be in same position factory set the switch. I had one like that also switch was little crooked so I straighten it up and walla worked.
Posted on Nov 23, 2008
My gas furnace wont kick on when it has been off for awile, we have replaced the thermostate and checked eveything else. Once we gett it going it works but wont kick in once the temp drops
Posted on Nov 30, 2008
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Posted on Dec 11, 2008
tborn6
  • 700 Answers
SOURCE: Rheem Criterion II Furane would not ignite
what you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Posted on Dec 25, 2008
Nordyne mobile home furnace will not ignite. I REALLY need an answer ASAP
Turn down room thermostat switch power off to unit turn power back on turn up stat see if this resets unit .
Check to see if pilot is on . check to see if you have gas to you unit if not then it could be the reg on the tank .
Oct 24, 2016 | Grilling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
My nordyne m1 mb 056a bw heater isnt working...a red light flashes twice, which means "Pressure switch is open"...how do i fix it?
First, I am assuming that this is a residential gas fired furnace. 1. The first thing that will happen once the furnace gets a call for heat is the small draft inducer motor will come on. 2. The pressure switch should close. If the switch is not closing, here is a list of possible reasons: 1. The draft inducer motor is not running. 2. There is a restriction in the flue or heat exchanger. 3. The tubing from the pressure switch is not connected or has a leak. 4. The pressure switch may be defective or stuck open. Note: this is not an exhaustive list, but should cover the most common causes. Also, you may have to unplug the furnace and then plug it back in before it will try to come on. It may be locked out on the control board because of the pressure switch fault. I hope this helps!
Nov 30, 2015 | Heating & Cooling
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
? 13:25
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Gibson Furnace KG6RC-060C-12A Model
Somewhere on the unit there is a small chart that identifies the problem that the lights are indicating. That helps narrow down a long list of possibilities. However, if you catch it acting up you can check that limit switch like this:
with your voltmeter set to voltage test from one side of the switch to the other. If the limit is "open" due to an overheat problem your meter will read 240 or 24 volts depending. If the limit is closed/working it will read 0 volts. The unit must be running for this test. The problem is there is a small window of opportunity before it cools off and closes. Whatever you do, DO MOT BYPASS THE LIMIT!
Feb 13, 2014 | Gibson Gas Furnace 60000 Btu 90% Afue...
York diamond 90
The problem could be clogged hoses or hose connections or a bad pressure switch. Remove one wire from pressure switch start furnace as soon as inducer fan starts reattach wire if furnace runs replace pressure switch.hope this helps
Dec 11, 2013 | Heating & Cooling
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Mar 12, 2010 | Heating & Cooling
Heating & Cooling Logo
525 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
