Diagram to change a 6 volt 1940 farmall to 12 volt
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Use this link:
http://www.antiquefarmalltractors.org/forums/index.php
Then Register (upper right corner of page) after that post your question there. These guys are serious Farmall Tractor people they will be more than happy to help you.
Posted on Oct 07, 2010
Need wiring diagram to change from 6 volt to 12 volt. Have '48 8N tractor still on old 6 volt system need to rewire to 12 volt system
Only thing needed is to change battery , leave wires alone , unless there is a wiring problem , wiring diagrams are avalible on internet, pdf ...
Nov 19, 2017 | Garden
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
Battery will not charge on Farm 1940 Farmall Cub Tractor it is not a lawn mower
check voltage at with tradtor running pull off pos side of battery see if your getting voltage for 6 volt 6.5 to 7.5 volts for 12 volts 12.5 to 13.5 if low voltage go to voltage regultor if volt or low go to generator test there if low replace gen if voltage ok generator replace voltage regulator
Sep 02, 2014 | Garden
How do I hook a 6 Volt Battery up on Farmall Cub Tractor
look for positve on battery a + sighn is what you are looking for on battery then find positive battery cable in tractor no witch it between pos cable neg cable hook neg to battery fist to battery then hook up positve cable ready to start
What would cause the alternator to run hot on a 1949 farmall cub tractor
Sounds like your still running power thru the original regulator also. Disconnect the original system completely so that your running power directly from alternator's inboard regulator and to the battery. Nowhere else.
Aug 31, 2014 | Cars & Trucks
Alternator wiring diagram on farmall M tractor
from scratch... well are you using the factory style of alternator or something different as you didn't mention the age and it could be: 12 volt positive or negative ground, or, 6 volt positive or negative ground. Or do you have a starter/generator or ??? Further research suggest you have a generator which would mean you have a voltage regulator somewhere... SO please help us help you. We need to identify your system before we can help... Pictures would be great. Numbers would be good, type of battery would help...
Aug 29, 2014 | Garden
I am converting farmall h tractoer electrial system from 6 volt to 12 volt. Need a diagram of wiring using an alternator
If the kit contains a wire and a diode, one would ASSUME it is a standard "3-wire" alternator, rather than a less-desirable (goofy) "one-wire" unit.
Here's a simplified diagram.
Please note the diode, an "idiot light" or a 10 Ohm 10 Watt diode can be used interchangeably in the "excite" wire lead.
Jul 06, 2010 | Computers & Internet
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
