Question about Honeywell Air Purifiers
I have a Honeywell Duct Mounted Elec Air Cleaner- F50E. Until the last year, the device would "snap" when (relatively) large dust material would contact the unit. Now, it is completely silent and I am afraid it is not workinf. I "test" the unit but checking the tes button and the button "snaps." Still-- how do I know if the unit is really working, or if (1) the cells or (2) the unit needs to be replaced. I can tell from the level of dust in my house now compared to previous years that it is not picking up dust as efficiently as it did. Thank you. Appreciate any help. Mary Ellen Lynch
wbwill
  • 68 Answers
SOURCE: Sharper Image air cleaner housing
depending on its value, we are happy to take a look and give an estimate, contact me at wbwill@sbcglobal.net or on allexperts.com I volunteer there too
Posted on Nov 12, 2008
  • 252 Answers
SOURCE: Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Posted on Sep 26, 2009
HVACjake
  • 22 Answers
SOURCE: F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Posted on Jan 20, 2010
  • 25 Answers
SOURCE: I have a F50E electronic filter. The light comes
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Posted on Mar 25, 2010
Testimonial: "I think this has narrowed the problem to the board or the Cell. How do I test the Board? I used the Ohm meter on cells & got no reading."
liteswink
  • 99 Answers
SOURCE: The Honeywell electronic air cleaner constantly
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Posted on May 25, 2010
My honeywell electronic air cleaner snaps all the time
Just had the "snapping" problem over the last 5 weeks. First try was to wash the cells in the normal fashion. when the snapping started again in a week I washed the cells in the dishwasher. They began snapping again in a week or less so I removed the cells and made a very close inspection of them. Using a very bright light I noticed the wires had a very uniform coating of something light gray in color. I picked at that coating with my finger nails and it came off to reveal the BARE wire underneath, Ah Ha, that coating was NOT supposed to be there ALL the time. So, CAREFULLY using my fingernails and a bit of wooden stick I scratched off that coating on all of the wires (it goes all round the wire) to reveal the bare wire and now it works with out snapping. Those wires can be broken if you are not careful. They can be replaced but that's just more hassle than being careful.
Good Luck, be careful, it can be done by the homeowner (and should be done too).
Dec 29, 2011 | Honeywell (F50F1032) Air Purifier
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
Mar 24, 2010 | Honeywell Air Purifiers
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
My electronic air cleaner doesn't come on when my furnace come on anymore
it may be full of dirt / dust and the airflow switch preventing it from turning on. Or the door may not be fully closed preventing the unit to come on...safty device. do you have the instuctions for this unit? it may need to be reset.
Nov 24, 2009 | Honeywell Air Purifiers
Eletrical snapping sound
This is normal....when dust passes through this filter it is "Zapped" that's how the electronic air filter works
Oct 25, 2009 | Honeywell HFD-130 Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
F50E New Power Supply Arcing
check the fins on both cells for even spacing on the fins. If the fins are bent a little, this will cause your arcing.
Pull both cells out and reinsert them one at a time. Keep the cell all the way to the front or all the way to the back so it makes contact with the power supply.
The cell that has bent fins will continue arcing. Good luck.
Nov 13, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Air Purifiers Logo
169 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
