Question about Motorola MC75
An MC75A we are testing is failing to scan the bar code on U.S. driver licenses approxmately 10 to 15% of the time. The bar code is scanned but there is no beep and no "read". The remaining 85 to 90% of the time we get a good read. Interestingly, when we use an old 75 model it is successfully scanning the bar codes that the 75A failed to read. Is the scanner on the 75A a poorer quality device?
5 Suggested Answers
  • 3 Answers
SOURCE: the device doesn't scan the bar code
Try changing to new battery.
Posted on Apr 02, 2010
Yogger
  • 117 Answers
SOURCE: Hello, I have the Motorola LS3478-FZ
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Posted on Sep 21, 2010
Yogger
  • 117 Answers
SOURCE: scan bar code using motorola MC75
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Posted on Nov 19, 2010
  • 58 Answers
SOURCE: Hi. I have problem with scanning
WHAT SCAN ENGINE DOES THE UNIT HAVE? PLEASE CONTACT ME AT JACK@CODEO.CO.UK
Posted on Nov 08, 2011
I have a 2004 jeep Cherokee 4.0L cars sputters at 2000 Rpms changed the spark plugs and ignition coil and also fuel filter also changed battery and alternator still has the same problem I'm stumped
If check engine or service engine light is on get the codes read. There are numerous things it could be. Randomly throwing parts at it probably won't fix it and just waste time and money.
Jul 16, 2016 | Jeep Cars & Trucks
How to program a bar code scanner to have 3 "TAB" in prefix
In the appropriate manual (see link)
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
May 16, 2016 | Zebra LS2208-SR20007R-UR
Why does my LS1203 scans only first 7 digits of bar code?
its in the settings youll need a settings barcode chart to change that
Jul 25, 2014 | Zebra Symbol LS 1203 Barcode Scanner
Abs light and driver airbaglight stays on
why not scan it. and wonder 2nd.?
if a USA car , you can scan the PCM,BCM ABS and SRS bags.
the code leads you to a cause. (leads,means more tests)
the FSM shows the codes, that leads you (more tests) to actual bad part.
most scan tools (cheap ) cant scan this. in usa. (autozoned helpers fail)
i have a $200 tool that does this.
my Innova 3160 , scans my jeep, 2008, and says it does 1999 GC.
YMMV.
i'd take it to any ASE mech and ask him/her to scan it.
the look up the codes
at alldata.com
if all that sounds too hard (it is)
then get it fixed.
there are only 2 choices,
DO not put head or body near the bags when fiddling any WIRES.
ever or BOOM, (death or near)
Feb 25, 2014 | 1999 Jeep Grand Cherokee
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Symantec Scan engine sees nothing wrong with eicar test files
in a command line? it looks like you did not put the path of the eicar file that you're scanning...
Aug 11, 2009 | Symantec AntiVirus Scan Engine 3.0 Upgrade...
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Motorola MC75 Logo
277 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
