Question about GE Dryers
I have a GE DX4500EE1WW electric dryer. Over the weekend it stopped working. If you turn the start dial you can hear it hum so I know it's getting power but the drum won't turn. I've tried it on every setting. Could it be the belt?
    Problem Solver:
  • 15 Answers
MOST LIKELY A BAD MOTOR OR SOMETHING CAUGHT IN THE BLOWER WHEEL. UNPLUG UNIT, TAKE TOP PANEL OFF AND THEN FRONT PANEL. PULL THE DRUM AND BELT OUT AND LOOK INTO BLOWER HOUSING FOR RESTRICTION AND SEE IF YOU CAN TURN MOTOR BY HAND.
Posted on Oct 06, 2010
Ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
Jul 25, 2010 | GE DBSR453EBWW Electric Dryer
GE electric dryer not working
It sounds like your motor is failing.You went to turn it on and it hummed... The motor got hot and triggered the safety shut off. When it cools you may be able to get it to hum again. But you will need to replace the motor.
Let me know if I can help you further.
Apr 15, 2010 | GE DWSR405EBWW Electric Dryer
My electric GE dryer stopped working today, when
sounds like the motor is running, the belt could likely be broken and be the culprit, this is if the motor is turning for sure after you start the dryer
Sep 30, 2009 | GE Dryers
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
GE gas dryer not turning on
Humming sound might be igniter trying to fire up but fails.
It might be eitther bad igniter or bad gas valve.
Please kindly let me know if you need more info. I am always here to help
Good Luck
Feb 01, 2009 | Dryers
Dryer will not start
Faulty Drive Motor
If the motor will not start, it is possible it is defective. The wiring of the motor is different for each brand and you will need to refer to the wiring diagram of your dryer for the specific terminal locations. You will need to use a volt/ohm meter to check for resistance between the run winding and common (may be referred to a neutral). If there is no resistance, the motor is open and will need to be replaced.
The motor bearings can also go bad. A dryer with a motor in this condition can sometimes be started by hand and it will run. However when the motor gets hot the bearings begin to seize and the motor will stop. In this condition you must also replace the motor.
Dec 05, 2008 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
191 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
