Question about Garden
I have a stihl 009L chainsaw the stop button dosent work I cleaned the saw out but I still have to pull the spark plug to get the saw to turn off .
    President:
  • 1,627 Answers
Check to see if the ground to the switch is okay,if it is replace the switch,if not replace the wire or wire end.
Posted on Oct 06, 2010
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
No spark on my stihl 009L
disconnect ground from coil and try for spark again. If you get spark now then you have a short in your ground wire if no spark still replace coil
Oct 11, 2014 | Stihl Garden
How does the gasket kit go on a stihl 009l model311y go
You need to strip the carb step by step take a photo of the striped down carb showing diaphragm and gasket positions re-build is reverse of strip down.make sure all carb parts are extreme clean before you commence re-build good luck.
Jul 17, 2014 | Stihl 009l/010/011 Brake Handle Solid...
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Saw is cutting the wood on an angle
the cutters on your chain are not filed evenly. Either take saw to a Stihl dealer and have chain sharpened or get a new chain. Ask them to show you how to sharpen your chain.
Apr 23, 2014 | Stihl 009l
I can't get my stihl chainsaw trigger throttle and trigger interlock to catch so I can start it. I pressed them both at same time but does not catch.
Release the interlock button first, then the trigger throttle. If this does not work, replace the interlock button.
Oct 23, 2013 | Stihl 009l
I need a parts diagram for stihl 009l chainsaw
Stihl does not have a parts list anywhere,they have it where you have to go to them for anything,spark plugs is one thing you don't buy from them,6.95 versus 2.95 at Autozone,ngk .
Dec 11, 2012 | Garden
Garden Logo
333 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
