Question about Whirlpool Refrigerators
My Whirlpool refrigerator model ED22GW makes the ice but won't dispense, any ideas why?
    Problem Solver:
  • 6 Answers
If it has never dispensed ice,the mfg places a stopper in the dispeser during production. remove it. if the ice just jams up and wont come out, use non-stick cooking spray around the opening of the dispenser. they can jam up if you dont use them often enough and little droplets of water freeze up. either one of these should help, if not I have no idea whats going on and you should call the person who sold it to you.
Posted on Jan 13, 2011
Ice maker stopped dispensing ice.
Did ice maker stop making ice? Or the dispenser is not dispensing the ice? Is the correct model number ED5FHAXV? Sea Breeze
Mar 09, 2013 | Whirlpool ED5FHAXV (253 cu ft) Side by...
Whirlpool refrigerator won't make ice--just out of warranty
I would have to say control board but you could look for a bin level switch. This is what tells the machine that the ice Bin is full. If it is duty or damaged the machine will never make ice as it thinks there is enough already there
Sep 05, 2012 | Whirlpool Refrigerators
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
My Whirlpool refrigerator Model # ED5RHEXNL00 Ice maker broken
Hello. Thanks for choosing fixya! The most common cause for your problem is that someone accidentally raised the wire in the icemaker area that turns it off. Check that first if the wire is up, push it down and within a few hours you will have new ice. The second most common problem is that the cubes in the mold got stuck in there. the fix is to use a blow dryer to free them up, then dry out the mold and spray some PAM cooking spray in to the mold to lubricate it. The final possibliity is that there is ice in the water supply line that feeds your ice maker. Once again get out the blow dryer and thaw that ice so that the water flows once again. good luck with it. regards, joe
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
Usually when this happens the water line in the freezer is frozen. If this is the case, defrosting the freezer should free it up and all will work again.
Aug 02, 2009 | Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
251 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
