Question about Sunbeam 5891 Bread Maker
I do not have a book,so how do you get the pan out to clean?
    Problem Solver:
  • 5 Answers
Twist it then pull. try both anticlockwise and clockwise.
Posted on Oct 07, 2010
Is sunbeam electric fry pan model 7710 type 787 still available
Sunbeam Frying Pan‎
www.shop411.com/Sunbeam+Frying+Pan
Many Sunbeam Frying Pan
Find our Lowest Possible Price!
Nov 01, 2015 | Sunbeam Multi Cooker Frypan Fry Pan...
Oil leak? pan or valve cover? placed cardboard template under oil pan-shows oil all over area template?
there are only but a few leak points, on this water cooled engine.
  1. valve cover gasket tops list.
  2. the 2 distributor o-rings, leaks down bell housing.
  3. or the distributor base housing not mounted and sealed by the book. (need book?)
  4. front cam seal (cover off look)?
  5. front crank seal (or the bolt was never set to 94ft/lbs, torque. 17mm head bolt.
  6. pan never leaks its glued on day one in the Cami factory with RTV, unless prev. owner fiddled with it. (new oil pump done wrong)
  7. last it the rear oil seal, rear to leak.
there are only 2 way sto find leaks, get it clean, drive short distance.
see what leaks.
or
use the dye kit, a kit with UV lamp and dye, pack.
id do a #! valve cover, the 60k mile inspection , adds one, and most of these cars get on 60k service, ever , so the gaskets are all hard.
and useless on every one ive ever seen.
see oll behind here>?
http://www.fixkick.com/t-belt/sneak-a-peek.html
Mar 14, 2015 | 1997 Geo Tracker 2 Door
COULD YOU SEND ME A BOOK ABOUT COOKING BREAD?
I have the recipe book for that machine for sale that I could email to you. reach me at daryl441@msn.com
Oct 14, 2014 | Welbilt Bread Machine Pan Abm 600-1 pan...
Need to find parts for GE JBP24DOM1WW
We have no parts reference books nor are we a source for any parts. All we can do here is google the part. Just google this phase "Quick Clean Oven parts" and hope the search returns a few results that will lead you to a parts source online.
Jan 16, 2012 | GE JBP24 QuickClean Electric Kitchen Range
Changing transmission filter in 2000 jeep wrangler 4.0 need diagram
No Diagram needed. Lift front of Jeep on Ramps or Stands, Remove 4 nuts which hold the transmission to the skid plate. Remove 6 bolts that hold the skid plate to the frame. Remove all but the 4 corner bolts holding the transmission pan. loosen the 4 remaining bolts with a big pan under the transmission and let the fluid run into the pan. remove the 4 bolts and drop the pan. remove the 3 screws holding the filter and remove filter. Clean the pan and magnet in the pan. Install new filter and put everything back together. Fill with fluid. The video is not for your year but the job is just the same
Tranny filter and fluid change on the MYJ jeep
Aug 18, 2011 | Jeep TJ Cars & Trucks
2002 s type 2.5L oil pan leak 1) Does anyone know
Hello your Dealer is going right by the book on labour now a day's garages are by law aloud to go by the book quote to do the job the book is about 7-8 hours but i have seen the job completed in 6.5 hours by someone who has allot of experience and has done several of them.So all in all they are aloud to go by the book and yes your quote is pretty much accurate and yes it is a big job hoist needed.
Jan 24, 2011 | 2003 Jaguar S-Type
Does my griddle pan on my Frigidaire 5 burner
I just got a new range and the instructions to season the griddle are in the instruction book. Wash an d dry the griddle. coat all surfaces ( top and bottom ) with a thin coat of cookin oil. place in oven at 350F for one hour. turn off afer an hour and let cool in the oven.
Jul 02, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Leaking fluid
Only so many places these trans 41 TE can leak on the vans. Lines on top, speed sensors(input, output)one is below the lines the other is to right of the lines. Dipstick tube, trans solenoid gasket, Oil pan & extension gasket. Wipe off & clean area very well. Lines leaking, check clamps first before replacing. Speed sensor leaking replace o ring, Dipstick tube replace o ring, Trans solenoid replace gasket, Extension plate replace gasket If the pan is leaking you change the trans filter & put a gasket on the pan. The book says RTV on the pan, but FelPro make a gasket for the pan $6.99. Use a Chrysler trans filter!!!! O rings for sensors, tube around $3 each, trans solenoid gasket $3, extension gasket $10, Filter $11 + gasket $7 & 4qts trans fluid if doing the filter or extension gasket.
Jan 18, 2010 | 2000 Dodge Caravan
Remove oil pan from 2007 Saturn Hybrid Vue
Believe it or not, it is a VERY simple task. Take a flat-tipped screwdriver and tap in between the motor and oil pan. All automotive books say the SAME thing. This is regular practice and will NOT damage anything. You have to pry the pan off. If it is adhered this good....make double sure you clean both surfaces off before re-applying the new pan gasket. A scraper (has a razor blade on the end of a handle) will help the clean the block surface.
One thing to remember, once you get the gasket sealant oneither the block or the pan, let it set till it is tacky. Then, as you put the pan back up, work a cross pattern to install the bolts and only start them finger tight. Once you have all the bolts on, tighten then again in a criss cross pattern and try not to overtighten them until you have them all snugged down. Then tighten them to specs. DO NOT OVER TIGHTEN!!! You gasket will start to "seep" out and then you will have to repeat the process for a leaking oil pan.
If you need more info, post a comment again.
Mar 15, 2009 | 2007 Saturn VUE Green Line
Remove oil pan
Try this, before removing bolts, breaking loose the factory gaskets seals, fighting with cross members and steering joints, some vehicles can never get done correctly unless a professional mechanic with proper tools and educated ways of removing a oil pan. clean it up where the crack is place some paper towel there after draining out all the oil you can, hint-- might need to sit a day with clean paper towel under it making sure its not releasing any more oil out the crack, scrub it with sand paper when its all dry and clean place some "seal all" brand glue over the crack seal all works on oil, grease, gasoline,must be absolutely clean and dry first. after two coats it dries fast then place some paper in third layer to give more stability to the patch. most of the time you will not need to replace the oil pan. if it still leaks get a good book on your vehicle in the public library they give instructions on most all repairs.removal and replacement.
Nov 09, 2008 | 2002 Saturn L-Series
Sunbeam 5891 Bread Maker Logo
18 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
