Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it & i can't get it off to fix the cord. hope this makes sense. thank you!
  • 171 Answers
Even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Posted on Oct 07, 2010
  • 3 Answers
9999999999
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I NEEDED TO FIND OUT HOW TO INSTALL A POWER CORD ON A KENMORE CANNISTER VACUUM (WHISPERTONE) NOT A KITCHEN STOVE.
Hi emery1950,
I have provided you instruction on how to remove the motor canopy to get to the reel cord area and how to replace the reel cord. Kindly click on this link.
Hope it helps.
Thank you for using Fixya.
Apr 13, 2011 | Kenmore Whispertone 23312 Bagged Canister...
Dear Technician, I have a problem with my cord to retract back in the canister vac. Would you please help with this problem solution. ...
Try tilting the vacuum so the front is at about a 75-90 degree angle to the back. Gently tug and release cord. This will usually retract the cord.
Jan 20, 2011 | Electrolux Lux 5500 Canister Vacuum
The cord is jammed and won't come out, is this an easy fix?
it should be, you can open it up and rethread the cord around the spool
Jan 08, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How do i open canister for cord retract repair
There are four screws under the lid, and there are two additional screws under the face plate for the controls display. You'll need a thin, flat blade screw driver to "pop" the face plate off. The two additional screws that you are looking for are deeply recessed about the bracket-nozzle park.
Jun 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Jan 14, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
704 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
