Question about Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White
Where is the relay of compressor - Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 /
Posted on Oct 08, 2010
There is a clicking sound like something is trying to turn on, the freezer has quit cooling and now the frig is begining to shut down what can it be?
How To Replace the Compressor Relay The compressor relay is accessed from the lower rear of the refrigerator. The compressor relay is located in the terminal box which on the side of the compressor.
Before replacing the compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced
Reattach the wire to the new compressor relay and press the relay back onto the compressor terminals. Replace the terminal cover box and plug in the refrigerator.
Aug 18, 2011 | GE GSS20IEP Side by Side Refrigerator
Refrigerator is not getting cold enough and i don't here the compressor coming off/on.
Check the compressor relay.
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. In the photo below the compressor is labeled "A", the relay is located in the terminal box which is located at the position labeled "B".
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
Test the compressor relay for continuity using a multimeter. Set the multimeter to the ohms setting X1.
With the relay upside down, place the probes into the terminals labeled "S" and "M". The multimeter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up).
With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The multimeter should now display an ohm reading of infinity (or the tester should not light up).
Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L".
The multimeter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity.
With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M".
The multimeter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms.
If the compressor relay does not pass all of these tests, it should be replaced.
Jul 23, 2011 | Refrigerators
Less than 2 years old; fan still runs, but no water being removed. Pan is totally dry. Ideas? Anything I can fix on my own?
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the dehumidifier. The relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the dehumidifier to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Jul 10, 2011 | Haier 45-Pint Dehumidifier
Compressor makes a buzing sound and then clicks off.
Change the start relay.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by a tension spring or with a retaining clip.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor. Remove the compressor relay by pulling it straight off from the compressor.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced.
Jun 03, 2011 | Refrigerators
Kenmore refrigatorstart/relay/overload switch has burned spot on
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each model). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
Jan 09, 2010 | Kenmore Refrigerators
Our FRT18G4AWE top freezer, bottom fridge. Compressor isnt kicking on, freezer is freezing but fridge is luke warm. can here compressor hum very faintly, if you get next to it. Is compressor done or what?
HI. I would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each modle). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
Dec 21, 2009 | Frigidaire Refrigerators
COMPRESSOR NOT COMING ON
HI. This will require you to test the compressor and relay component. Test the relay first, then, the compressor last. if the relay fails the test, replace it, but if both the, compressor and relay, passes there respective test, the culprit will be a failed main control board.
THE RELAY
Nov 17, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My refrigerator dosen't cool or freeze
the hot piece is the compressor.the clicking is the relay trying to start the compressor.generaly when im out on a service call and the compressor is hot and relay clicking the compressor has failed internally.because if the relay was clicking but the compressor was not hot there was a chance only the relay was bad and not allowing power into the compressor.but because the compressor is hot that tells me the relay is letting the power to the compressor but the compressor cant do anything with it because it locked up and its absorbing that power getting hot and then clicking on overload you could try a relay but i don't think it will help. God bless ,tom
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Freezer has quit working and now refrigerator not cooling like it should.
If you hear the start relay clicking after the compressor tries to start then you know that there is power to the compressor.
This tells you it is ether a bad start relay or a bad compressor.
At this point I use a meter to see if the compressor is shorted to ground.
If the compressor is not shorted then replace the start relay and give it a try.
You should hear the compressor start right away with a new start relay if that was the problem.
If the compressor is shorted to ground you will need to have the compressor replaced.
Given the history on whirlpool refrigerators in the 5 year old age range It may be good chance that a new start relay will fix your refrigerator.
If the start relay is bad you will hear it try to start the compressor and then click off.
If the relay is bad you will hear the clicking sound seconds after plugging it in and then again every minute or two as it keeps trying to start the compressor.
Jun 02, 2008 | Whirlpool Refrigerators
Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
