Question about LG LFX25960 Bottom Freezer French Door Refrigerator
Is bowing of floor between refrigerator and freezer in LG model LFX25960SB fixable?
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101...
Posted on Oct 08, 2010
Freezer wont freeze
If your freezer is not freezing 1 possible problem is a freon leak. Check out this blog. It could help.
On Time Appliance
Jun 03, 2015 | LG LFX25960SB 26 cu ft French Door...
My lfx25960sb lg refridgerator won't defrost it builds ice on the coils the heater looks ok
Looks cannot always tell if there is a problem with the defrost heater or defrost thermostat. Your model uses the=> 5300JK1005D Defrost Heater Assembly and the=> 6615JB2005H Defrost Sensor Unplug before working on your fridge. Can you find an ohm meter and remove he rear panel in the back of the freezer? I can walk you through this if to lie. Also tellme what type of frost pattern you see once the rear panel inside the freezer is removed. Completely frosted over? Half or less frosted over? Clump or ball of ice where the small tube enters the large copper tube on the evaporator? Just ask questions on your post here on Fixya I am here to help, Thanks, John Tripp Appliance 911
Jan 31, 2014 | LG LFX25960 Bottom Freezer French Door...
I have an LG french door bottom freezer refrigerator. Water is coming out of the back freezer vents and then pooling and freezing on the freezer floor. If we don't remove it periodically it leaks onto the...
This has nothing to do with the ice maker. The defrost drain has frozen over. Inside the freezer you will see that the whole back is a panel. Unplug the unit and gently pry at the top of this panel. It will come forward and then you can lift it out. unplug the fans and take the panel out. You will see the coils. and underneath the coils, the drain pan. Mine was completely filled with ice. I used a hair dryer to melt it and remove the large chunks. Be gentle. Use a turkey baster to remove excess water. Then pour some very hot water in to clear the drain itself.
Sep 04, 2013 | LG LFX28968ST Refrigeration : Refrigerator...
Water gathers in bottom of freezer and thaws out and runs on floor. model LRFC25750TT
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | LG LRFC-21755ST Bottom Freezer...
How do i remove the covering of the wheels to lock them. it is an lg refrigerator with bottom freezer
LG refergiators have floor stops that screw down to contact the floor to keep it from rolling when the doors are opened.
There is one stop on each side, In front of the front wheels.
You may need to remove the toe kick grille to see them.
Check your installation book or online @ www.lgusa.com
Jan 15, 2010 | LG LFX25960 Bottom Freezer French Door...
I have a lg lfx25960sb,it is showing ER IF code on the panel above ice /water door,also not making ice?
ER IF indicates that the ice maker fan is not working. The fan is probably frozen. Remove the fan duct and housing at the back of the freezer and you may be able to defrost the ice in the fan enclosure. It will not defrost sufficiently by turning the freezer off for 2 to 4 hours as LG suggests. The fan may have frozen because of high humidity or because the defrost cycle is not working. If your unit is still under warranty LG should fix it by replacing the fan, duct panel and control board with new ones that have been re-engineered to prevent this problem.
Dec 16, 2009 | LG LFX25960 Bottom Freezer French Door...
Hole burning through floor of Freezer
Your refrigerator is likely a frost free model. There is a heating element that runs around the freezer compartment. It is probably the heating element that is causing the original damage to progress.
Most fridges have a way to turn off the frost free part, usually via the timer or or easy as pulling the fuse for the circuit. Pull the fridge out, climb behind it, unplug fridge, and remove access cover, if equipped. Look for a wiring diagram. It will tell you where you need to disable the frost free at.
If you can't disable the frost free, then replace fridge now. the acrid smoke you smell is toxic, and is detrimental to food, as well as to human life. Stop using the fridge, or disable frost free.
Nov 02, 2009 | Magic Chef CTB1922 Top Freezer...
Water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
May 27, 2009 | LG LRFD25850 Stainless Steel French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG LFX25960 Bottom Freezer French Door Refrigerator Logo
125 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
