Question about Denon AVR-2500 Receiver
Denon avr 2500 preamp outputs strapped to main inputs. how do i utilize pre outs?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Jul 04, 2017 | Denon Audio Players & Recorders
Hookup a pre-amp and equalizer to a Denon AVR 982
Hi
you can choose any input on the Denon and select it from the front panel
setup the Equalizer and the preamp connections and plug it in the selected input on the Denon.
Thats it.
if u haveany Questions dont be a stranger.
good luck
Mar 16, 2016 | Denon Audio Players & Recorders
No output to the subwoofer using the sub pre out RCA jack.
I'm assuming your subwoofer is self-amplified, otherwise it won't work with a preamp (rca) input.
Under Speaker Setup you have to have Subwoofer set to YES (page 16).
If you have good bass-capable main speakers I would recommend setting the subwoofer playback mode to LFE+Main, otherwise just LFE.
Beyond this we would need to know something more about the subwoofer and its controls.
Connect any other preamp out channel, like CDR/Tape OUT, to the sub and tune an FM station to see if the sub is capable of processing audio. A 'normal' audio signal would sound muffled but it would prove the cabling, amp and speaker at least function and point us back to setup as the culprit.
Dec 08, 2010 | Denon AVR-587
How do i hook up my yamaha natureal sound eq-70 to a denon avr 591 receaver
from cd analog output to input at the yamaha, then from output to dvd/cable/ cinch input at the Denon. faae4fd.jpg
Sep 03, 2010 | Yamaha Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
Play phono - vinyl records
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Dan
Feb 25, 2009 | Denon AVR-1602 Receiver
Denon avr-2500 left main speakers very quiet.
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Jul 26, 2008 | Denon AVR-2500 Receiver
106 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
