Question about Bosch Dishwashers
On my Bosch shy56a 05uc/14 the washing process freezes at the 1 minute mark and sticks there. How can I fix this please?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
On my Bosch shy56a 05uc/14 - dabfa62.jpg
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 06, 2010
  • NoMorTosh4Me
    NoMorTosh4Me Oct 18, 2010
    You may want to check the Bosch website as many of their dishwashers are under recall for a faulty controller which may cause a fire! I just set up my appointment for the recall repair.
  • Mark MacDonald
    Mark MacDonald Nov 01, 2010
    Recall does not apply to these dishwashers...look at the list before commenting please.
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Aug 09, 2012 | Water Heaters
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Owners manual misplaced, model SHY56a02uc/14
Hi Friend,
U can download the Manual from the below link provided
http://kitchen.manualsonline.com/manuals/mfg/bosch/shy56a.html
Copy and paste the Link in the brower
in the web page will be having a download button click it u can view the manual
Or if its needed i can send u a mail kindly provide the mail id
Regards,
Ayyasamy
Jun 15, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Fitting washing machine boot gasket/door seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
605 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
