Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
All of a sudden a totally dead e-machine
Dead...... New Power Supp. is installed. I'm not sure about pwr. switch. wires black&white where to plug in to connector.This is an Intel motherboard. T-2984. A photo or sketch would be helpful.
  • 23 Answers
I believe this would be for your board
Try ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
for the manual.
Use http://www.intel.com/support/motherboards/desktop/d845gvsr/index.htm
for all motherboard related support.
Posted on May 31, 2008
Why my juki ddl-555-5, wheneve I turn on the power switch, just run split second then it automatically turns off?
Try swaping the wires that you cut you might have them backward.if that don't doit you might try changing the hole cord to a new one .
Apr 01, 2017 | Juki DDL-8700
Tried to start 2001 chev blazer, would not jump from another vehicle, wont start put it in neutral , rolled back vehicle then started, does it whenever it feels like it, new battery,alternator, etc ...
I'm using this older report to include an attached photo of the Connector that plugs onto the Neutral Safety Switch...Note that the top row has 4 female pins...These are signal wires for the transmission and not involved with the starting contacts of the switch...The switch has more then one set of contacts because it performs multiple tasks...We are interested in the bottom row of 3 female contacts...The 3 wires have the following colors; Black/White= the chassis ground input...Purple and Purple white= The Neutral/Park Safety contacts...It is these two wires that connect when the switch is closed when placed in Park or Neutral...When a new connector is installed, as you can see, all the wires are White and are spliced to the factory colors...The two outside pins in the bottom row of three pins (not the one in the middle) are the Purple and Purple/White wires...Push the points of two safety pins into the rear of the in-place connector into the two outside slots until they touch the pins that the wires are crimped to and connect a multimeter set on the X1 ohm scale to these two safety pins; Put the shift lever in Park and then Neutral (key OFF) You must read zero ohms as in a dead short...This proves that #1...The contacts are properly closing...And #2...That the wiring is correct...When in Park/Neutral Battery is supplied to the Starter Relay Which pulls allowing the Starter to run...send a comment
Saailer
Aug 22, 2011 | Chevrolet Blazer Cars & Trucks
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
Satelite Toshiba M45-S165. WOrked fine, now won't boot
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
May 11, 2009 | Toshiba Satellite M45-S165 Notebook
Pull switch wiring
What you have is a switch for a ceiling fan/light combination.
Black wire from your light is power, White is Neutral (do not connect this to switch or dead short).
Apr 17, 2009 | Refrigerators
Hitachi EC12 AC is "dead"
you should take the cover off where the pressure switch is (the on off switch) and see if any wires fell off the connectors. the white wire should go straight throu to the motor, then the black wire will go to the switch than the pressure switch then to the motor. if you are careful enough you could temperarly straight wire the black wire from the cord to the motor wire.
Apr 12, 2009 | Hitachi EC12 Portable Electric 2hp Air...
I have a new dishwasher and it won't start. it is set for normal wash and heated dry. when i close the door and push start, it doesn't start.
You don't say if it does anything at all or is just dead. I'll guess just dead.
First, make sure you have power to the dishwasher. Breakers all on? Some homes have the dishwashers plugged into an outlet under the sink. Usually one of these outlets is switched (for disposer) and the other half of the outlet is live, for a dishwasher. If you have the outlet connection, plug a lamp into the recepticle to make sure you have power. Some outlets may even be "downstream" from a GFI recepticle which may be tripped. Second, you may have to check to make sure the twist wire nut connectors are all good and tight on the white, black, and ground wires at the connection to the dishwasher. Hold the wire nut and tug on the wires to make sure they stay in the wire nut.
Aug 27, 2008 | GE Dishwashers
Casablanca W32 Fan and Light Switch Reversed
Check to see if the wiring at the fan is reversed - perhaps the neutral (typically white) & hot (typically black or red) are swapped.
If this is not the case, check to see if the neutral & hot are switched for the entire circuit.
Feb 26, 2008 | Dryers
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
116 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
