My harddrive, or fan goes off and on which seems to slow the computer. If I am I correct, what is the solution? Thanks
  • 68 Answers
If your hard-drive is heavily fragmented, it needs to have a defrag done with either Windows built-in program, or, third-party program designed to do the same thing. I recommend "Auslogic's Disk Defrag" for this, it's fast and light of your system's resources.
Hope this helps. :)
Posted on Oct 06, 2010
  • mlmead70 Oct 07, 2010
    Did not fix. Thanks for trying.
  • IceCake
    IceCake Oct 08, 2010
    It seems as if you're saying that when ever the fan of the computer turns on and off, things start to slow down.
    When your computer starts to get sluggish, it can be due to several reasons, I'll list them below........
    1.) Your hard-drive needs to be defragmented. Download and install a program like "Auslogic's Disk Defrag", a fast and very lite on resources program that takes care of this.
    2.) You have too many programs starting up with Windows. When you start up your computer, look at the lower-right corner of the desktop. If you see a long line of icons listed in a row, that's more than a necessary amount of programs running in the background. This puts a heavy strain on the computer, which then, slows it down. You really only need just your "firewall' and "anti-virus' running at startup.
    You can easily stop unnecessary programs from starting up when your computer starts. Go to the "start" button, next click "run", (Vista, Windows 7 just type into the search area), now type "msconfig" (without quotes) and hit enter. You'll see a window pop up, look for the "startup" tab at the top-right, click on that. Next, look for anything that you know is a program installed by you and uncheck those (except for the firewall and anti-virus programs), or, to make it even easier, uncheck everything that doesn't have the words "windows" or "system32". Remember, leave anything associated with your firewall and anti-virus "checked". Now, click "apply", ok, and if asked if you want to restart or reboot, click "restart now" or "yes". Your computer should now reboot and return without all of the added programs to slow it down. :)
    3.) You don't have enough computer memory (ram) installed to handle all of the programs that you're running. Check your manual that came with the computer to see how much ram the PC can hold. Install the maximum amount to help your computer run faster.
    4.) Spyware, malware, and adware has installed itself on the computer and needs to be cleaned off (this stuff slows down the PC!!). You get these "computer parasites" when you visit different websites and download some "FREE" programs that silently add the junk when installed. The best program I've seen to clean your PC of the stuff is called, "SpyBot Search
Wont start
If you're not getting a beep code then you can be almost certain the problem does not lie with any of your hardware aside from your CPU.
It is possible your CPU is overheating, in which case you can try to increase the fan speed in the CMOS setup. For further troubleshooting I recommend using isopropyl alcohol to remove the old thermal paste from the heatsink and CPU die, and apply a new, small, pea-sized dab of thermal paste to the CPU die (after which you remount and lock into place the heatsink and CPU fan).
Sometimes these startup problems are very simple, and since you said the fan slows down rather than stopping, it could simply be you have a loose connection somewhere. I'd start with the PSU cables for the motherboard and CPU, and then the fan-monitoring plugs on the motherboard.
Also, it never hurts to load the default CMOS setup, and if you have any expansion cards you'll want to reseat all of them.
Jan 08, 2014 | ASUS Eb1501P-B016E - Eeebox Eb1501P-B016E...
Asus K53SD HARDDRIVE SLOW
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Dec 01, 2013 | ASUS Computers & Internet
After starting the game the comes till loading then it goes off
Possible that the harddrive is not running at its normal speed,
freezing up or slowing down. Or has quit.
My computer took 20 min. to boot the other day.
I was watching the HDD activity indicator light,
and it would remain on, and not rapidly blinking.
Mechanical devices do have problems.
Harddrive manufacturers have software for download for testing HDD.
As for my laptop, I had it off for several months, then took over one hour to get the harddrive cranked up to speed.
Also DUST inside Desktop computers can gum up harddrives.
Is yours clean.????
http://www.makeitsimple.com/project...
^^^ Some pictures ^^^
Feb 16, 2011 | Health & Beauty
Why does my fan seem to be cycling at all times which is slowing down the computer big time
your fan has nothing to do with your computer slowing down.
your fan goes on when a threshold is reach in the cpu temperature or another component's temperature being cooled. the question is what's is causing your cpu or your chipset to work harder than usual causing your system to seem to be sluggish??
the simple answer is malware and need for a clean up and tune up
I suggest you do the following:
1. get an air can, open the case and without touching anything and watching for ESD, dust off your system free.
2. close the case and turn your computer on
3. update your antivirus and run deep scans
4. get all critical updates for your system from windows update
5. download, spybot search and destroy, malwarebytes, superantispyware, and a square free edition, update them and run deep scans.
6. defrag your hard drive
7. to improve perforamance make sure you update or upgrade memory
good luck!
Apr 23, 2010 | Gateway 831GM PC Desktop
Hp computer. hard drive light is solid yellow pc non working
What has transpired is the power supply is bad. Electrolytic Capacitors inside have failed. These capacitors relate directly to the voltage power rails of the power supply. They are filters.
Little more detailed.
Your computer power supply converts AC electricity into DC electricity. (A flashlight battery is an example of stored DC electricity)
AC comes into input Electrolytic capacitors. Goes to a rectifier bridge, and on through various other components. Along the way, this DC voltage is considered 'Raw'. It needs to be a steady, 'clean', supply of DC voltage. There are Electrolytic capacitors used in the final stage, to convert the 'raw' DC to 'true' DC.
In a computer power supply the Electrolytic capacitors are the weakest link. They are usually the first component to go out.
You computer power supply converts AC voltage into three DC voltages. 3.3 volts, 5 volts, and 12 volts. These are the power rails.
When one, or more Electrolytic capacitors are weak, they make a weak voltage rail.
To simplify explaining the construction of an Electrolytic capacitor, let's just state they are small aluminum 'cans', and have a seal at one end, or both ends. Inside there is an Electrolytic paste.
This paste can break down, and when it does it forms a gas. (Hydrogen gas) This gas expands inside the 'can', pushes up on the seal/s, and makes Electrolytic paste ooze out.
So much paste loss, and the capacitor can operate in a weakened state. Too much paste loss, and the capacitor fails.
ALL the lights in your computer use less than 1 Watt. EACH fan uses 2 to 3 Watts. A harddrive just sitting there spinning, may use up to 5 Watts.
A processor uses 55 to 125 Watts! Depends on the make and model.
Since the power supply is to weak to provide enough power to turn the processor on, the harddrive isn't activated. It just sits there and spins. No Boot record on the harddrive is found, so no Operating System is going to be running. (WinXP is an example of an O/S)
This essentially means No computer! Harddrive activity light indicates yellow, then goes out. There is no harddrive activity.
No signal from the computer, because the computer isn't working.
Monitor stays in Standby, because there is no signal from the computer.
Power supply failure is 70% of computer issues.
Why?
Owner neglects to keep the inside of the computer, and the power supply clean. Doesn't use a can of compressed air for computers regularly.
Also there is another issue that the owner has nothing to do with.
Capacitor Plague.
http://en.wikipedia.org/wiki/Capacitor_plague
Solution? Replace the power supply.
I know the above info may seem like a 'Hard pill to swallow', but as stated. A weak power supply will still spin fans, and light lights.
Harddrive may spin, or spin up, then stop.
The processor isn't getting enough power.
Apr 12, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
My computer is running slow.
hi , the slower of the pc has many causes , could be hardware or software issue, after you upgrade the meomory and you still face this problem, so the only issue it seems now is the harddrive, try first to format the harddrive this could fix the problem since most of freezinf issure caused by softwares installed in the hard drive, if you donot want to format it, there is alot of progams can help you check your harddrive and fix the problems. let me know if i can help you in anything else, thanks for joining fixya.com.
Mar 01, 2009 | Dell Inspiron 1501 Notebook
Sata harddrive
You need to enter the BIOS and check to see if the sata drives are enable cause if there aren't then you'll always get that response and seems as tho you waste your money.
Also you must have the sata drive on primary.
Get baC @ ME!
KJ
Apr 22, 2008 | ASUS P5LD2-VM Motherboard
My hard drive is not working
is the system load the bios or nothing happen ? In this case the system not detected the memory maybe the memory lessen, fix it firmly and start the system again.
disregard the solution above if the harddrive is detected in the bios. there is a four connection in the IDE /PATA hard drive.
P master
P Slave
S Master
S Slave
if you connect or use one IDE cable in two connection, the other should be in slave. master is where the Operating system is.
try to verify the hard drive label for a master or a slave harddrive.
If this solution not solve, please notify me b4 u rate so that i can give you further solution. thanks!
Jan 28, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
