Question about Zebra LP 2844 Thermal Printer
Error message on stamps.com says: error initializing printer. I have used this printer lots and lots of times and this just started popping up.
Ok 2 things either your firmware is outdated or your driver... i do have the same problems due to my driver is not correct...plus when i updated the driver i forgot to set printing orientation and paper size
first go to
http://www.seagullscientific.com/aspx/thermal_95.aspx
scroll down to zebra click download
then install it
you will see 2 printer in your printer and fax in control panel
right click on the LP2844 (not the Zdesign LP2844)
select printing preference
go to page setup tab
choose 4x6 from the drop down menu in(stock)
then apply
also dont forget to go to option to set the darkness uncheck the use current printing setting
go for 12- 14 the default setting is to light sometime might not scan..by usps...
since everytime you updated the driver ...your setting might go on default...that why you'll need to go back and reset the printing pref...
after i did it ...the stamp.com doen't have problem at all
hope this help
http://www.etsy.com/shop/iamyot
Posted on Oct 11, 2010
Hp laserjet 3055 has error message on copying "50 fuser error, turn off then on". Restarting brings on the same message when copying.
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the cabling connections to the heating element.
4. Turn on the power and wait for the all-inone to initialize.
5. If, the error persists, replace the fuser.
NOTE The device power mustremain off for at least 20 minutes forthe fuser to cool down and correctly reset.
Turn off the power switch, wait at least 20 minutes, and then use the power switch to turn on the all-in-one and wait for it to initialize.
Aug 23, 2011 | HP LaserJet 3055 All-In-One Printer
HP color laser jet 2600n. Shows 51.22 error
after you replaced the cartrige,did you run a initialization?
Sep 07, 2008 | HP Color LaserJet 2600n Printer
Im having problem with my epson T13 ..with message ink out error..how can i fix it? anuone can help me?tnx a lot
Just use the "Initial setting" on the menu and check the initial setting checkbox and input the printer's serial no. and click perform on the adjustment program by OrThoTaMiNe and turn off your printer. Then turn on, and the ink out error will be gone.
Jan 09, 2011 | Office Equipment & Supplies
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Print head error message
hi
if yr printer is under woranty u need to do company services system coz i think that u do what as u abov say that u do a initial stape or if yr printer not on woranty and if u know a normal clining system do cline pritner otherwise u need to replace head...
if yr printer show red light blink do press 5sec. then print it..may be it's help u if u have any quary tell me feel free...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Error message-"printer had any motor mis-step error"
After 8 yrs..........Get a life and new printer! Inkypete
Apr 21, 2009 | Alps MD 5000 Thermal Printer
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
ATI Error message pops up very often
http://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Download and install this before installing the ATI drivers. Hope this helps
Dec 26, 2007 | Adobe Photoshop 7.0 for PC
Zebra LP 2844 Thermal Printer Logo
2,227 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
