Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator not working - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER, a no agitation problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem yourself and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If the washer IS running, but the agitator is slipping, then you may have worn agitator dogs, or a loose agitator bolt. The following link explains what the dogs are, and how to access to acces the bolt and replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you may need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided. If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on Oct 07, 2010
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
Agitator issues
The agitator coupling beneath the agitator needs replacing. It is stripped.
Pull hard on the agitator to pull it off the shaft to expose the coupling. Remove the coupling and replace it with a new one. Replace the agitator.
If the agitator is hard to remove,use a old leather belt under the agitator to pull up on.
Watch your nose when it comes loose.
Feb 18, 2010 | GE Washing Machines
My washer stopped adjutating but it drains the water out what is the problem
The agitator is driven by a couple of different methods. The first is the agitator is spline and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Aug 07, 2009 | GE Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitator works intermittently
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
-no agitation
Hello
Welcome to Fixya
My name is Huum,
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
70 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
