Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have water dripping from the icemaker area, and pooling in the bottom of the freezer. The repairman cannot come out until Monday, what can I do in the meantime to ensure that I dont damage the unit or my flooring?
    Sergeant:
    Champion:
  • 351 Answers
Full tube has come out of ice maker or funnel has frozen up
Posted on Oct 08, 2010
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
instead of ice maker heres a more common problem
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Icemaker does not work on subzero 650
My ice maker on the Subzero 650 is up and running again. After checkig the tray and shutoff mechanism thoroughly I checked the display in the fridge aea and noticed a "service icemaker" indicator. I turned the icemaker off and then on again with no change. I then turned the power to the entire refridgerator/freezer unit off, waited ten seconds, and thurned it back on. This apparently must have reset some type of logic because the icemaker immediately began to cycle (ice ejector began to turn slowly) and then I heard the water soelenoid turn on to inject water into the ice trough. It's been 24 hours now and the icemaker tray is filling up nicely. I guess my icemaker just need to be rebooted. The miracles of modern technology. I appreciate the suggestions posted in response to my posting as well as the postings of others with similar issues as well as te corresponding suggestions. All of these together lead me to investigating areas that ultimately lead to resolution. I probably would have called for an expensive repairman if not for this forum. THANKYOU!
Dec 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
